Old 09-26-2015, 09:53 AM   #11
nomad297's Avatar
Originally Posted by davegood View Post
Would banging the thing possibly get it to work? I'll try that today.
Banging it might very well work, but you should try doing it first with no water pressure and then with water pressure. I am a plumber and I know that a swift whack with the jaws of a Channellock is the remedy to many problems.
Bruce
Old 09-26-2015, 11:24 AM   #12
Hoglou's Avatar
So on a sunseeker the water for the black flush enters from the outside of the coach, goes to a vacuum break somewhere in the coach and then back to the black tank?
Well you got me to walk out in the rain. The B&B manufactured inlet for the black water flush is identical to the external (park) water inlet product. I am still betting that the back flow check valve for the black water flush is just behind the three screws holding it to the exterior coach wall. Why would FR do more than required? That alone is whole new thread...
I am not a plumber so is the vacuum relief and back flow preventer the same thing?
or am I (punch line here) all wet.....
Hoglou westGA
KM4HQQ 146.640mhz
Old 09-26-2015, 11:33 AM   #13
Witch Doctor's Avatar
In simple terms YES. There is a valve in the black vacuum valve that can stick.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 09-26-2015, 11:37 AM   #14
Hoglou's Avatar
B&B inlet
B&B inlet
Hoglou westGA
KM4HQQ 146.640mhz
Old 09-26-2015, 11:45 AM   #15
bubbles's Avatar
Yes, the connection for the BT clean out looks identical but there is no check valve behind it. Only heard of one unit that had both the inside and outside check valves (I think it was a manufacturing mistake). There is not supposed to be 2 check valves in series for the BT clean out. See a previous post with image and read verbiage on that sheet. I have looked at other companies that make BT clean outs for rv manufacturers and they all say the same thing. The install is dictated by IAPMO TSC 27 if done by an rv manufacturer. A backflow preventer may not be vented to the atmosphere but a vacuum relief valve will be vented to the atmosphere. Our BT check valves are a combination of a spring loaded back flow preventer and a mechanical shut off plunger vented to the atmosphere which allows it to seal off the input side once the pressure is removed. The terms are all used interchangeably because the function is the same but in reality how that function is accomplished could be very different.
Old 09-26-2015, 11:59 AM   #16
If you have stinkbugs in your area - our previous Heartland twice had the check valve clogged by stinkbugs! When we went to get a new valve, another customer came in with a "broken" check valve. We tapped it on the counter and a stink bug fell out! Our check valve was behind the shower controls. As an aside, one year when I started the water heater, it started smoking - the entire gas line was filled with stink bugs and they caught on fire! We had installed all of the bug screens as an extra precaution on the vents but they can squeeze in anywhere.
PS - We are much much happier with our Forest River Rockwood Windjammer!
CLewis is offline   Reply With Quote
Old 09-26-2015, 12:11 PM   #17
Hoglou's Avatar
Great info about the valve.
Thanks!
Hoglou westGA
KM4HQQ 146.640mhz
Old 09-26-2015, 12:13 PM   #18
bend302's Avatar
CLR fixed my clog. Poured it into hose until hose was full and pushed it in with water.
Worked really quickly
Bill
bend302 is offline   Reply With Quote
Old 09-26-2015, 12:52 PM   #19
" I am still betting that the back flow check valve for the black water flush is just behind the three screws holding it to the exterior coach wall. Why would FR do more than required? That alone is whole new thread..."
Wouldn't that be nice. However the flush (behind the three screws) connects to a verticle tube that runs up to the very back of the sink, connects to the backflow valve, then another tube runs down to the black tank. Other water lines were installed in front of the valve, making it inaccessible. A horrible design. Shame on Forest River!
davegood is offline   Reply With Quote
Old 09-26-2015, 05:14 PM   #20
Hoglou's Avatar
I think I found my next mod...
Hoglou westGA
KM4HQQ 146.640mhz
black, black tank, black tank flush, tank
