Old 05-29-2016, 06:10 PM   #1
Black tank flush valve
Why does my flush valve seem stopped up or shut off? 2016 Sunseeker 3010DS
izzaboomer is offline   Reply With Quote
Old 05-29-2016, 06:15 PM   #2
fonzie's Avatar
Maybe black tank flush line are reversed at vacuum break valve.....see thread below.
Black Tank Flush
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 05-29-2016, 09:07 PM   #3
Forester Fred's Avatar
I had issues with mine too, I'm thinking sawdust from construction got into it and clogged it.
Black tank flush issues - need input
2015 Forester 2301 - Chevy
Skip & Deb
Forester Fred is offline   Reply With Quote
Old 05-30-2016, 06:38 AM   #4
Okay let me be more specific. I didn't want to tell this part. I made a dumb rookie mistake. I mistakenly hooked up fresh water line to flush valve and walked away. When I realized what I had done black tank was full and seems like it even filled grey water tank. Now flush will not work. What have I done? How can I fix it?
Old 05-30-2016, 06:49 AM   #5
This is whats called a "Paul Harvey"! Full disclosure helps! Check your B&B made valve! Youroo!!
Old 05-30-2016, 07:11 AM   #6
What is a B&B made valve and where is it?
Old 05-30-2016, 07:12 AM   #7
And what am I checking for?
Old 05-30-2016, 07:58 AM   #8
I have the same problem of black tank flush valve seems stopped up. I made the mistake of hooking fresh water line to flush valve and walked away. When I realized what I had done the black tank was full and seemed like the grey tank had filled. How do I fix this so my flush valve will work and I can flush my black tank again?
Old 05-30-2016, 08:21 AM   #9
Mr. Dan's Avatar
It's the black thing in the pic in post #5.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 29; booked = 12
Old 05-30-2016, 08:42 AM   #10
SeaDog's Avatar
I'm a little confused if your black tank filled when you hooked up to the tank flush system then the system is working. Its not a good idea to flush your tank without having the dump valve open. If your tank if full dump it
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
black, black tank, black tank flush, tank
