01-18-2017, 01:26 PM
Black water tank cleaning
Just but a 2015 Sunseeker 3010 which has a water input for sewer tank spray cleaning. No instructions on how to do this...can anyone help..thx
01-18-2017, 01:34 PM
Connect water hose to inlet of sprayer, open black tank valve, turn on water. Let it run until clean enough. A clear elbow helps you determine.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
That is basically a spray cleaner for your black tank Noting special in operating it other than making sure you have the black tank drain valve open when you use it as you are introducing water ( under pressure) into the black tank and it needs somewhere to go. Most people do not use a pressure regulator on the line feeding the sprayer. Drain your black tank and then run the sprayer. It helps if you add a clear elbow between the back tank drain valve and the drain hose so you can see how it is working. There should be a sticker n the unit near the tank wash valve reminding you to open the black tank drain.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
01-18-2017, 01:38 PM
Out of Order
Congrats on your purchase! If like mine, you simply screw the hose to the input and the other end to the hose bib/faucet. Once you turn on the water, the tank will begin flushing with a spray of water from the doohickey mounted in the tank. Mine takes about a minute to flush out the gunk and turn the draining water from brown to clear. I will close the valve occasionally to let the tank partially fill with clean water and then pull the valve to aid in flushing action. Just be SURE not to close the valve for too long or close the valve and walk away. Filling the closed tank to overfill would be disastrous...and gross.
BTW, never use your fresh water hose for this procedure. I'm not sure how much back spray there is or isn't into the hose but it's just disgusting to even think about. I have a dedicated black rubber hose I use solely for the black tank rinse.
Todt and Connie and Hank the Doodle
2016 Wildcat Maxx 24RG
2016 Ford F250 6.7L Diesel
01-18-2017, 01:47 PM
The black tank flush is basically a built in sprayer to help clean out your tank. When I use ours I dump the tanks, leave the black dump valve open, connect a non-potable water hose to the exterior flush port and turn on the water. After a couple minutes I watch the water coming out of the tank, thru a clear sewer hose connector, to see if anything but clear water is being flushed. After I see only clear water running I turn off the hose and let the tank finish draining before closing the black tank dump valve.
Even though black tank flush ports should have a back flow preventer, a one way valve to keep black water from backing up the valve in to the hose, I do not use our fresh water hose, for potable water, to clean the tank. I use a cheap garden hose for all non-potable water usage. The white water hose is for fresh water, the green garden hose is for potentially slimy water...
Wayne
2024 Sunseeker 2150SLEF / Ford E-350 chassis on order.
2024 Coachmen Northern Spirit 1943RB
2021 F-150 4X2 SuperCrew Lariat 502A, 3.5L Powerboost Hybrid, 3.55 gears, Tow Technology Package, Tow Mirrors, 1,840# Cargo, 7,000# Tow, 7.2KW Pro Power, Sumo Springs, A.R.E. Z2 Topper
It is better to have too much truck than to have too much trailer.
01-18-2017, 01:55 PM
Insert witty title here
The sprayer on mine does a lousy job. If I really want my tank cleaned, I fill it up about 1/2 way with water, take a bumpy drive then dump it.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
01-18-2017, 03:11 PM
Thanks, great answer and advice
01-19-2017, 10:25 AM
My unit did not come with one.
I added an aftermarket one and mounted it about 1/3 the way up the tank- so I can leave the valve shut for a minute or so, let it fill up some- then pull the valve and let it keep running. Works great so far.
"If you are going through hell..keep going"
W. Churchill
01-19-2017, 10:35 AM
I also use one of these and it does a fairly good job.
01-19-2017, 03:23 PM
I use one of these on my black tank hose, available from many sources from about $12. Search for garden hose water meter.
RAINWAVE WATER TIMER .. SAVE WATER - FLOW METER
After dumping the black tank I close the valve and fill to about 2/3 full using this meter, dump again, repeat then run flusher with valve open until tank drains clear. I verified the accuracy of the two meters I have by filling 5 gal buckets and comparing the volume measured. Both were very accurate.
I also use one on my fresh water hose when partially filling the fresh tank prior to a trip (I carry 10 gal for roadside toilet/sink use).
2017.5 Cedar Creek 34RL2
2018 F-350 Lariat CC SRW PSD 4x4
USMC Fighter Pilot (Ret)
01-19-2017, 04:35 PM
If I want to verify just how full my black tank is, I just look down the toilet.
Sent from my iPad using Tapatalk
01-19-2017, 04:40 PM
Lucky you!
My discharge pipe from the toilet to the black tank has a 45º ell in the plumbing.
I would never see the level until it was coming up into the toilet!
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=64
01-19-2017, 05:00 PM
Originally Posted by 5picker
Lucky you!
Same here.
01-20-2017, 08:22 AM
If you keep up on maintaining your black tank the flush system will work flawlessly
I use the sewer clean out in my front yard for a home drain
(White capped sewer)
My tank is never left with waste in it
We come home from a trip and I religiously clean the black tank and clean clear water flows in just a few min
I threw the wand sprayer in the basement,there is no reason to drag a dirty hose through your home and stick down a toilet.FR put this system in so you can perform this task quickly,cleanly and efficiently.
Keep up every trip or when you dump on long trips and life is good
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
01-20-2017, 08:40 AM
(Dry Huunday)
X2
and having a "straight shot" helps prevent a lot of potential "problems"
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
01-20-2017, 09:17 AM
degates, ..... please look at the link below, in post #3 and #13 of that link you will find info that no one else has mentioned, ... what I describe happening in #3 is a fact, .... and in #13, I explain why it's advised against closing the valve while spraying/filling your tank, .... there is a big difference between closing your valve for a 1-2 minute spray and closing it for a 20 minute spray/filling(that's just common sense), ... anyway, just thought you should hear another idea on tank cleaning, ... happy trailering ......
http://www.forestriverforums.com/for...sh-124831.html
01-21-2017, 08:20 PM
Things I learned the hard way - but all is good in black tank flush land now. No problems since I disassembled, cleaned and reassembled, it works great now.
http://www.forestriverforums.com/for...ut-106550.html
2015 Forester 2301 - Chevy
Skip & Deb
