Old 07-24-2016, 08:31 PM   #11
Previous Member
The wires you have in question my be for the Artic heating units on the storage tanks near the rear wheels Grey and Black tanks They may have the heat pads on the bottom under side. Just have a look under them. They are small gage wire 12v Allan Kay
allan kay is offline   Reply With Quote
Old 07-31-2016, 04:00 PM   #12
3071DS
Garrette's Avatar
Blow out rear tire. Question
The wires are probably your clearance lights. The wires are routed along a rail forward of the tires. Insulation covers them up. I had a tire failure last month. Took out the wiring for the clearance lights. By the way, you may not have any clearance lights, tail lights or tag lights. If not, You will need to replace fuse #22 in the fuse box under the driver side, behind the parking brake. Mine is currently in the shop to replace the fender well. Beat it up good and opened a hole into the sub basement. Got a replacement light from Amazon. If the wires have a small clip on the end, clearance light forward of the wheel. Just get a new one and route the wire flex behind the bracket.
Garrette is offline   Reply With Quote
Old 07-31-2016, 04:20 PM   #13
3071DS
Garrette's Avatar
Posted a few pics
Name:	ImageUploadedByForest River Forums1469999731.598733.jpg
Forward of tire
Name:	ImageUploadedByForest River Forums1469999776.283238.jpg
Opened a hole into sub basement
Name:	ImageUploadedByForest River Forums1469999818.797890.jpg
Clearance light wires
Name:	ImageUploadedByForest River Forums1469999964.692723.jpg
Now, I have this with TPMS thanks to Tireman9.
Old 07-31-2016, 04:30 PM   #14
ilmor's Avatar
Originally Posted by colestat View Post
We had a blow out of our inside dually passenger side tire this morning. It ripped out 2 sets of wires which no one can tell me what they are for.
Our leveling jacks work.
Our lights work
Our slide works
Our brakes work.
We do not know what these wires went to. Can anyone help. I will try to attach a picture in my next post.
Do you have tank heaters (Arctic pack)? Those wires are usually not well protected.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 07-31-2016, 04:32 PM   #15
ilmor's Avatar
First thing I'd do is get rid of the valve extensions. I've had them fail on me.
Old 07-31-2016, 08:31 PM   #16
3071DS
Garrette's Avatar
The valve extenders did not cause my problem. I added them afterwards to support the new TPMS. I think I had a puncture as I had a very slight vibration in the steering wheel that I blamed on the road. I now have a TPMS that will alert me on that condition. So I installed the extenders to make tire checking easier. Had all of this on a get list, just pushed the purchase to the top. At the next tire replacement, I will look into the all metal, longer valve stems.
tire
