Old 07-22-2016, 06:37 PM   #1
Blow out rear tire. Question
We had a blow out of our inside dually passenger side tire this morning. It ripped out 2 sets of wires which no one can tell me what they are for.
Our leveling jacks work.
Our lights work
Our slide works
Our brakes work.
We do not know what these wires went to. Can anyone help. I will try to attach a picture in my next post.
colestat is offline   Reply With Quote
Old 07-22-2016, 06:41 PM   #2
Sorry I do not know how to add a picture.
Old 07-22-2016, 06:57 PM   #3
Ford Idaho's Avatar
Check all rear 110v and 12v outlets.
Check any 4 or larger trailer/toad outlets.
Tank sensors?
Generator?
Flux Capacitor?
Old 07-22-2016, 07:12 PM   #4
Commercial Member
Our lights work
Our slide works
Our brakes work.
If you have voltmeter you can test to see which wires if any are hot. Sometimes wire color can help identify which if any are ground and the VOM should be able to confirm if 120v or 12V. Be careful. Start with everything shut off and have assistant turn on one item at a time.
RE tire failure. Have you read the thread "Why Tires Fail"
I know your current question is about the wires but preventing failure in the first place is a good idea. And if you don't know why the tire failed you may not be able to prevent a recurrence.
How did you discover the failure? If you don't have TPMS ( I am assuming you don't) there is no way to know how many miles you drove with the one tire loosing air which means you were overloading its mate and may have done serious structural damage to it. It needs to be dismounted and you need tire dealer to inspect and pronounce it OK IN WRITING.
Is the P/U a FORD? A Ford dealer should be able to ID the wires.
I write a blog on RV tire application and safety. RVTireSafety.com
Also give seminars on tires at RV events across the US. 40 years experience as tire design & quality engineer for major tire mfg. Freelander 23QB on Chevy chassis is my RV
Tireman9 is offline   Reply With Quote
Old 07-22-2016, 07:21 PM   #5
Please post which forest river you have and model number. It is tough offering help if we don't have a clue whether you have the same RV as we may have.
Uploads can be accomplished by following the instructions shown below.
down below the frame where you type your message is an area called "Additional Options"
Click on the "manage attachments"
It will bring up a popup screen that allows you to upload attachments from your computer or phone depending on what you are using to access this site.
Hope this helps,
shermand
ShermanD is offline   Reply With Quote
Old 07-23-2016, 01:37 PM   #6
If your Sunseeker has Michelin tires, you may be in the period of a tire recall.
The recall was 2010 to 2012. If yours is a 2013, the cutaway may have been built in 2012 and the MH titled as a 2013. Worth a check.
Recall alert: Michelin recalls truck, RV tires | Clark Howard
PenJoe is offline   Reply With Quote
Old 07-23-2016, 02:45 PM   #7
Commercial Member
If your dealer registered the tires as he is required to do by Federal Regulation you should have received notice in the mail. BUT I would not count on either FR or an RV dealer doing what they are suppose to do as far as tire registration so check your DOT against the list.
Old 07-23-2016, 05:17 PM   #8
Thank you PenJoe for the information about the tire recall. I also have a 2011 Sunseeker with those tires and I never received any information about a recall. I will call Michelin tomorrow to see if I can get new tires.
rhughsless is offline   Reply With Quote
Old 07-23-2016, 06:05 PM   #9
Upgrade your tires.
  • With one gone, and one possibly damaged, this seems like the perfect opportunity to upgrade your tires. Get tires rated for 81 mph and a higher load range. Most trailers are close to the load range limit of the tires under them, and that is a recipe for disaster.
mnoland30 is offline   Reply With Quote
Old 07-23-2016, 06:44 PM   #10
Pre wired back up camera?
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2016: 19 nights
Miles traveled in 2016: 2,575
uhduh camping is online now   Reply With Quote
tire
