Old 05-19-2016, 07:07 AM   #1
geeman53's Avatar
Blown LED tail light
We were told by our dealer that we need new LED tail lights do to moisture behind the curb side lens resulting in three blown LEDs. Our dealer says 4 to 14 days to receive .If your lens look foggy ,that is moisture.
2016 sunseeker 2250slec
1988 Jayco p.u.,Coleman Plantation p.u.,1989 Jayco class c, Coachman TT,1995 Little Eddie fthwheel,2007 Heartland Sundance 2500 lS fthwheel
geeman53 is offline   Reply With Quote
Old 05-19-2016, 09:50 AM   #2
Total Loss's Avatar
I had one replaced.
The culprit is the reverse light lense.
On my 2016- it had 2 screws holding it.
I ordered a replacement unit.
On the new one I received- it has 3- much better seal.
When you replace your Geeman, check for that.
If the other lamp has 2, take the lense off and seal it with some clear silicone before reinstalling.
I siliconed both of them- no moisture now.
Just a poor initial design on these new LED's.
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
Old 05-19-2016, 03:33 PM   #3
geeman53's Avatar
The dealer is installing , but I can speak to the tech. I believe they ordered two. Thanks for the heads up .
Old 05-28-2016, 10:48 AM   #4
geeman53's Avatar
Both taillights to be replaced ,Friday-6/3 .
Old 05-28-2016, 12:52 PM   #5
Citrus County, Fl.
GL1800Rider's Avatar
X2 on sealant. Mine had moisture shortly after delivery. I removed the back up lens to let it dry, sealed and re-installed. Never an issue since.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 05-29-2016, 07:31 AM   #6
geeman53's Avatar
Our' SS is under warranty , so our dealer gets the job.
led, light
