Old 05-01-2015, 07:33 PM   #11
GM
bclemens's Avatar
The parking brake thing is ONLY for the dash screen. You also need to look at the following two items that were posted on here prior.
Name:	Jensen Radio Remote Battery.jpeg
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 05-02-2015, 03:12 PM   #12
Excellent, I'll take a look at the remote the next time we have it out.
Any suggestion on the auto leveling jacks?
I was on a paved pad where if I didnt have auto leveling I would have raised the back by driving on 1.5" blocks.
I was pretty surprised the auto leveler tweaked the chassis so much the bathroom door wouldn't open.
We retracted the jacks all weekend and no one cared, but I don't like having these jacks the dealer told me were already adjusted working like this.
It was level with the auto levelers. I think it raised the chassis higher than it needed though.
6inthefamily is offline   Reply With Quote
Old 05-02-2015, 09:32 PM   #13
We have a magnadyne in dash DVDs that sends the movie to the cab over bunk. The quality isn't that great. We stopped at Walmart and bought a $90 portable did player with a 12 volt plug and direct hooked up. Now no issues, kids can change movies when they want.
MzZorro is offline   Reply With Quote
Old 05-11-2015, 03:04 PM   #14
Bclemens do you have the tv and dvd instructions for magnadyne systems?
rdeiss is offline   Reply With Quote
Old 05-11-2015, 05:00 PM   #15
GM
bclemens's Avatar
It's pretty much the same thing. The TV portion is the same, the Radio portion you will select AV1 or AV2 on the stereo.
Old 05-11-2015, 07:15 PM   #16
Did you try setting parking brake?
sonny bransom is offline   Reply With Quote
Old 05-11-2015, 07:23 PM   #17
I have a 3170 also. I did the big foot level system. No problems. Yours may not be set correctly. It showed to be same system installed at factory It's the full auto or manual system. I pull in and push the auto button and it sets up.
Old 05-11-2015, 09:19 PM   #18
Garrette's Avatar
I use the manual setting on my big foots. It lifts the rear too much on auto. Easy in manual mode and almost as fast. IMHO.
Garrette is offline   Reply With Quote
Old 05-11-2015, 09:26 PM   #19
benagi's Avatar
I have a 3171 on order, should be here the end of June. I am new to slide outs and big foot jacks. Would like to know what type of maintenance or problems I might be looking at. Thx, Ben
benagi is offline   Reply With Quote
Old 05-12-2015, 06:13 AM   #20
You can calibrate the auto level jacks. Press front button 5x. Then press back button 5x. Lights will blink, wait for it to go out. Manually put the levels out and manually level it. When you got it perfect, press retract button 3x. Lights will blink, now it's stored. Retract them, press auto, see if it works.
jjlavin is offline   Reply With Quote
