Old 09-20-2014, 03:22 PM   #1
Brackets for tv
I have a 2013 3170 that has the 24" tv in the front over the bunk. I think the tv is too small and I know they started putting the 32" in the new ones. After going to the Hershey show and seeing the 32" it made me go out and buy one. I didn't get a Jenson 12v because we really don't use it unless plugged in, plus the fact that $550 was about the best price I could find for one. The tv I got weighs around 10 lbs. so I know the existing arm will be able to handle it. It looks like I will need to get a bracket for the back to make it work. If anyone has swapped the 24" tv for a larger one can you tell me if a standard bracket will have holes line up on the arm in the camper or will there be some drilling involved?
Brian217 is offline   Reply With Quote
Old 09-20-2014, 03:51 PM   #2
Aluminum plate is what I used to convert to the larger screw placement. Works well.
Sun Seekers is offline   Reply With Quote
