You've probably already done it, but easiest thing to check is the fuses. Usually each side is fused separately, so if you're having issues with just one side, it's a good chance it's the fuses.
Sometimes when a brake/turn signal light blows out, the falling filament shorts out the bulb and blows a fuse.
2011 Traverse LT, 3.6L, FWD
