Old 02-29-2012, 08:51 AM   #11
zook's Avatar
Jamiller I was informed by Unified Tow Brake to use the AP Products adapter EC-4129 Pigtail marked Winnebago, that one has a small 3/4" square plug.. but I had also gotten a Pigtail from PPL that looks close to matching the plug you show in the picture.. so still not 100% what one I need.
But thank you very much in advance for the help so far..looks like I'm not the only one in need of this info..
zook is offline   Reply With Quote
Old 02-29-2012, 07:55 PM   #12
Wanderluster
OffPavement's Avatar
Originally Posted by jamiller45 View Post
As grizzly mentioned, I believe it is the connector on the backside of the coin holder on the dash. I will get ahold of my ford service guy to verify this. pictures attached to help you locate.
Along with the pix... Thanks! Now all I gotta do is figure how to remove the dash bezel to get to it. Did you notice... is it actually attached to a dash bezel somehow?
The Road To Paradise Is NOT Paved!
Brian & Margie
www.rv-camping.org
OffPavement is offline   Reply With Quote
Old 03-01-2012, 07:31 AM   #13
zook's Avatar
Ok this morning I got to the plug, it is as simple as pulling on the dash trim around the Radio, don't be scared just grasp it and pull.. this plug is directly behind the coin holder... more to follow..
ID:	10667   Click image for larger version
Old 03-01-2012, 08:43 AM   #14
zook's Avatar
This is the picture of the wiring harness I got from PPL for the Ford, as you can see it is a plug and play for the Prodigy brake controller,, my problem is the Controller for the Unified has different pig tails and the one I have does not match up.
ID:	10673   Click image for larger version
ID:	10674   Click image for larger version
Old 03-01-2012, 09:06 AM   #15
zook's Avatar
So my question is if I splice the plugs together what one is what? on the controller side I'm being told Black is ground, Red is Keyed power, Orange is brake lights, and Blue is line,
so on the Coach side is
Blue line?
Red?
Black?
White?
Old 03-01-2012, 09:54 AM   #16
Coachmen Adrenaline
ok here we go... on the top row of the plug starting with the yellow red and working towards the blue...
y/r - constant hot
purple - brake signal
black - ground
white/orange stripe - ignition switched on
I dont know what the blue wire does, it wasn't giving me anything. but the 4 above should be all you need. if you need help matching up how to splice them together or anything else just let me know.
jamiller45 is offline   Reply With Quote
Old 03-01-2012, 09:55 AM   #17
Coachmen Adrenaline
also the 2 small white wires on the bottom row have a constant 2.5Vdc. not sure what those are for either.
Old 03-01-2012, 10:21 AM   #18
zook's Avatar
I will have to look at what color from my plug goes into the plug on the coach. But all i have to work with is
Red
blue
white
Black..
Old 03-01-2012, 10:36 AM   #19
Coachmen Adrenaline
I'm certain you will do it correctly. feel free to ask if you have more questions.
brakes
