Old 09-10-2014, 04:30 PM   #1
Braking system
Hello All,
I have a class C 32 ft sunseeker, and I am going to be pulling a suzuki sidekick. Just wondering what type of braking system I should get.
Thanks for the help in advance...
Dakotablue is offline   Reply With Quote
Old 09-10-2014, 08:21 PM   #2
I have a 32 ft Sunseeker and I use Invisibrake. I pull a 2012 Equinox and there is no settings or daily adjustments. I did not want something I had to attach to the brake each day before leaving. I think you would be happy with it.
Bednarski1 is offline   Reply With Quote
Old 09-10-2014, 09:24 PM   #3
tmhyer's Avatar
I use the Blue Ox Autostop. I have a Sunseeker 3010 and a Jeep Cherokee
tmhyer is offline   Reply With Quote
Old 09-11-2014, 07:48 AM   #4
Sunseeker 3010, Tow a Focus, The Invisibrake works great.
Kevin & Judy is offline   Reply With Quote
Old 09-14-2014, 05:11 PM   #5
Hoglou's Avatar
Each to their own... i use a patriot on a jeep JK. Only one season thus far, but still like it.
Hoglou westGA
KM4HQQ 146.640mhz
Old 09-19-2014, 07:56 PM   #6
Garrette's Avatar
I use rvi 2 brake.
Garrette is offline   Reply With Quote
Old 09-19-2014, 07:58 PM   #7
Garrette's Avatar
I should say, I use rvi2 with the TPMS on my Subrau Outback. Works great for me.
Old 09-20-2014, 06:58 AM   #8
Frank & Eve's Avatar
We just went thru all this getting our new CRV outfitted to tow. Had the switch installed needed to prevent the need to pull the fuse the manual mentions. However when the switch is on it also turns off the 12volt socket needed for the braking system DH is going to wire a socket directly to the battery. First trip out with the toad next weekend !! We chose the Blue Ox complete setup.
Frank & Eve is offline   Reply With Quote
Old 09-20-2014, 08:18 AM   #9
Garrette's Avatar
Rvi brake has a kit for this, complete with 30amp fuse and heavy duty socket. Easy install. Also, check out their charging kit.
Old 09-20-2014, 08:23 AM   #10
Garrette's Avatar
http://www.rvibrake.com/RVibrake-12-...vkit-12010.htm
