Old 03-05-2016, 06:03 AM   #11
Originally Posted by OldCoot View Post
Replace the cheap FR breaker with a Cutler Hammer or Eaton. The ones that come in rv's are the cheapest ones built.
That is what happens when outfits go with "low bid". They may have a good system but not necessary made with the best material.
Back to the OP problem, yes, check the battery.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 03-05-2016, 06:57 AM   #12
TURBS's Avatar
Breaker trips when battery is on and we plug in .
Did you hook up the battery / batteries backwards?
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 03-05-2016, 08:06 AM   #13
2015 Columbus 320RS
2008 2500HD Duramax
He said things work fine if he disconnects the battery before plugging the cord in. When he connects the battery back up nothing trips, things work fine so that can't be the problem.
Sounds like a battery problem causing a heavy load on the converter when it is turned on with the battery hooked up. My question then becomes, why doesn't the breaker trip when he hooks the battery back up? If being caused by the battery when it was hooked back up the converter would see the same load, right? Could it be the 12 volt charger side of the converter is bad? The OP needs to check the chargers output as well as the battery/batteries.
Jim
George Bernard Shaw
Old 03-05-2016, 10:49 AM   #14
Where is the best place to purchase these? Are the breakers in Sunseekers a standard size? Thanks.
Originally Posted by oldtool2 View Post
. My question then becomes, why doesn't the breaker trip when he hooks the battery back up? Jim
Good question, Jim. I was thinking the same thing.
ActionJackson is offline   Reply With Quote
Old 03-05-2016, 12:48 PM   #15
Home Depot or Lowe's. Take the breaker with you to compare so you get the right one. They are normally standard size.
Jim
George Bernard Shaw
Old 03-05-2016, 12:59 PM   #16
Head Rambler
As for why it doesn't trip when he closes the disconnect. It's because the converter is powered up and the capacitors are charged, so it doesn't draw as much current when the battery is reconnected to the system as it does on an initial start when the converter is charging the caps and supplying a lot of current to the battery.
Gotta go campin!
Old 03-05-2016, 04:12 PM   #17
Jim
I'll go there. Thanks.
Sounds feasible to me. I think the OP's problem will be over with a new battery(s). I'm hoping mine will be over with a new breaker.
Old 03-05-2016, 05:37 PM   #18
Tom48's Avatar
Originally Posted by KyDan View Post
It sounds like you might have a bad battery.
The load of a shorted cell or bad battery might cause the converter to trip do
to the inrush of current as it starts trying to charge the battery(s).
Suggest you have battery checked for proper level of electrolite as well as
giving it a complete charge and then do a load test on it.
My lights do NOT dim when I switch off shore power. Yours shouldn't either.
2X
Tom48 is offline   Reply With Quote
battery, breaker
