Old 02-23-2016, 07:12 AM   #41
Who Dares, Wins
doc73's Avatar
I would need to unscrew and dump either way. Only way to get AF in my filter would be suck it through the tank.. Not gonna do that. AF fill it down stream from the filter, but I do not have a sunseeker.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 02-23-2016, 07:26 AM   #42
TURBS's Avatar
Originally Posted by jeffreymhardy View Post
So somewhere along the way in my winterization steps, I apparently neglected to get all the water out of canister that holds my water filter out. I did remove and discard the actual filter, left the canister empty but screwed back on. Today I went to "un" winterize for a weekend trip and discovered the canister cracked wide open. I think I know the answer to this but...does this mean I can't use any running water inside my rig since all the water gets filtered through that canister and there is none there now?
Just curious, how tight did you tighten canister when you winterized.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 02-25-2016, 09:26 PM   #43
I have had a couple of these crack and bought replacements from lowes. Now I just unscrew it and leave it off.
2016 Sunseeker 2700DS
2010 Jeep Liberty Toad
tlf65 is offline   Reply With Quote
Old 02-26-2016, 08:50 AM   #44
Wolverine 1945's Avatar
Smart Move !!!
Wolverine 1945 is offline   Reply With Quote
Old 02-26-2016, 09:28 AM   #45
No need to pull A/F from Tank,no need to put A/F in tank. A/F must be Pumped through the Pump for pump Freeze protection,this must be preformed on the Suction side of the Pump,otherwise not All the Chambers will be free of Water! Youroo!! And drain the little Pre Filter!
Old 02-26-2016, 02:51 PM   #46
Read about them cracking on this site and have always removed the canister and place in a drawer after winterizing is complete.
I should bypass it because we don't use it. We never drink water from the freshwater tank.
jst3 is offline   Reply With Quote
Old 02-26-2016, 03:21 PM   #47
We save our melted Ice water,,, run it thru a PUR water canister,,, and use it for cooking & coffee,,, we have done that for years because we used to camp on our own land,,, where there was no water available,,, we also @ that time used it to make more Ice,,, because it took over a hour to go to a store and back !!!
Waste Not,,, Want Not !!!
Old 02-26-2016, 08:54 PM   #48
The Factory filter also "Filters" all water from City Inlet,you might want to rethink Removing the Filter as it keeps "Things" out of faucets,toilet valves,ect. Youroo!!
Old 02-27-2016, 07:57 AM   #49
If we ever have to add water,,, we carry a filter to hook to the hose outside,,, I always filter all water before it enters the MH... nothing wrong with double filtered water !!!
Old 02-27-2016, 09:01 AM   #50
Chewie's Avatar
Are these canisters breaking only during freezing months? I understand the bypass mod, but I guess my question is are they breaking under normal use on city water?
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
Chewie is offline   Reply With Quote
Old 02-27-2016, 12:13 PM   #51
My Water Pur simply fell off one summer afternoon. Clean break all the way around towards the top, but not on the threads. Luckily we were there. I now make a habit of shutting the water off at the spigot when we leave for the day.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 02-27-2016, 12:35 PM   #52
Berkshire 390QS
NO3putt's Avatar
After winterizing, blowing out lines, then anti-freeze we just leave the filter off until we de-winterize. A little water in threads and cold will crack the filter in a heart beat. Bottom line, if not using the unit in winter, just leave the filter off. That filter is not available at lowes or HD, only can be purchased from water pur or from FR, or maybe a RV dealer.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
Old 02-27-2016, 03:43 PM   #53
Who Dares, Wins
doc73's Avatar
I've read many of a person whose filter just unscrewed itself right off its mounts... Some have even watched it turn itself off!
I have also started to shut off our water when we leave for the day to avoid a flood. We installed a HD / Lowes filter so we can get the filter anywhere on the road if I need a filter or the whole housing.
2015 Chevy HD D-Max
Old 02-28-2016, 07:59 AM   #54
We have always turned our pump off when ever we leave the MH,,,
We also turn our Well Pump off @ home if we are leaving for more than a day or 2 !!!
water, water filter
