Old 02-21-2016, 01:12 PM   #31
When I winterize my Georgetown 327DS, the compressed air going in through the city water connection will blow out around 80% of the water in the filter canister. I remove it , remove the filter, then reinstall it an continue blowing out the system. When all water is out, I run antifreeze in through the winterize hose to fill the sediment filter and pump housing with antifreeze. It's easy to see when this happens because the pink stuff starts filling the filter housing.
The filter housing is removed, dumped, threads wiped dry, and reinstalled until dewinterizing. Antifreeze is used to fill the traps and some is also poured into the toilet to make sure that there's some down at the black tank gate valve.
I've been doing this for five years now, with the RV sitting in Northern Ohio when winterized. We've had no problems with water leaks from freezing in the pipes.
Phil
pmsherman is offline   Reply With Quote
Old 02-21-2016, 01:28 PM   #32
Hoglou's Avatar
good bye filter
Well one thing leads to another... the filter is gone (but can be reinstalled) and repaced with a valve. Why a valve? Cause I used the parts I had in the drawer to prevent a HD trip...
Wont miss the water festival when winterizing...
Hoglou westGA
KM4HQQ 146.640mhz
Old 02-21-2016, 11:22 PM   #33
benagi's Avatar
Hoglou, how did you get the filter cap off the black plywood? I was going to remove mine and just make a bypass setup but couldn't figure out how to get to the screws holding the bracket that secures the cap for the canister. Your system looks just like ours.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 02-22-2016, 06:13 AM   #34
If you remove the filter element and then use compressed air (or antifreeze with the bypass) the filter housing will remain full of water. The pump will push water only through the top of the empty housing since there is no filter to force circulation down to the bottom. And...don't do what I first did. You can't get the housing off with water pressure in the system! Open a faucet and you can easily unscrew it.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 02-22-2016, 02:51 PM   #35
Hoglou's Avatar
Offset no.2 phillips screw driver. There are four screws on the top of filter bracket. Take it off first then unscrew the brass fittings. About 3 minutes a screw..... I later found my 1/4" wratched wrench that I could of put a bit in to then the removal would have been speeder. Tip to tip from the installed brass fittings on the filter top is 7.5 inches for the replacement pex line (finshed length with fittings). I just used a valve cause I was out of pex x 1/2 MPT ( Apollo PEX - APXMA 1212).
I have a water gizmo station I built in the rear of the coach bay. Hind sight would tell me to put a "t " fitting on the replacement pex line and add a little colied water hose instead. I have water access in the power cord bay and use it frequently to wash down the items from coach water. You get some interesting looks at the rest stop when you have your strechy coil hose out and washing you windshield in the truck lot..
No��
Hoglou westGA
KM4HQQ 146.640mhz
Old 02-22-2016, 02:56 PM   #36
flymhi's Avatar
Don't forget the clear little filter bowl on the sureflo pump. My first season I didn't even know it was there but by Spring, I found out real quick that it had cracked. Luckily it was a common part and a local dealer had it for $5.
2015 Denali Duramax 2500
2017 Coachmen 229TBS
2010 Shamrock 21SS - sold!
flymhi is offline   Reply With Quote
Old 02-22-2016, 03:09 PM   #37
Pickin' & Campin'
One more reason to draw antifreeze into the system for those of you who just blow the lines out with compressed air.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 02-22-2016, 08:34 PM   #38
benagi's Avatar
Lowe's part number would be very helpful...... Since our travel schedule is so random ( I mean we have decided on a tues that wen morning we are going for two day to see the grandsons) I often don't winterize when I should. Instead I open the outside shower and drain the fresh and use a thermo controled heat lamp (75 watt bulb) in the water bay. I do heat / cool the coach 24/7/365.
But we are in dixie....
See picture below for part number and brand. This will replace anyone who has the Water Pur Canister Part # CCI-10-CLW.
Also, thx for the info on how to get the cap off the bracket.
Name:	Whirlpool Cansiter.jpg
1968 tent trailer
1985 Jamboree 23 ft
Old 02-22-2016, 08:56 PM   #39
Who Dares, Wins
doc73's Avatar
Not really, I just unscrew the thing and dump it out.. Now it cannot freeze.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 02-22-2016, 09:57 PM   #40
Pickin' & Campin'
Draw in antifreeze or unscrew and dump out... Still just another step needed if you only blow out with compressed air.
water, water filter
