Old 02-23-2016, 06:12 AM   #41
Who Dares, Wins
doc73's Avatar
I would need to unscrew and dump either way. Only way to get AF in my filter would be suck it through the tank.. Not gonna do that. AF fill it down stream from the filter, but I do not have a sunseeker.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 02-23-2016, 06:26 AM   #42
TURBS's Avatar
Originally Posted by jeffreymhardy View Post
So somewhere along the way in my winterization steps, I apparently neglected to get all the water out of canister that holds my water filter out. I did remove and discard the actual filter, left the canister empty but screwed back on. Today I went to "un" winterize for a weekend trip and discovered the canister cracked wide open. I think I know the answer to this but...does this mean I can't use any running water inside my rig since all the water gets filtered through that canister and there is none there now?
Just curious, how tight did you tighten canister when you winterized.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 02-25-2016, 08:26 PM   #43
I have had a couple of these crack and bought replacements from lowes. Now I just unscrew it and leave it off.
2016 Sunseeker 2700DS
2010 Jeep Liberty Toad
tlf65 is offline   Reply With Quote
Old 02-26-2016, 07:50 AM   #44
Wolverine 1945's Avatar
Smart Move !!!
Wolverine 1945 is offline   Reply With Quote
Old 02-26-2016, 08:28 AM   #45
No need to pull A/F from Tank,no need to put A/F in tank. A/F must be Pumped through the Pump for pump Freeze protection,this must be preformed on the Suction side of the Pump,otherwise not All the Chambers will be free of Water! Youroo!! And drain the little Pre Filter!
Old 02-26-2016, 01:51 PM   #46
Read about them cracking on this site and have always removed the canister and place in a drawer after winterizing is complete.
I should bypass it because we don't use it. We never drink water from the freshwater tank.
jst3 is offline   Reply With Quote
Old 02-26-2016, 02:21 PM   #47
We save our melted Ice water,,, run it thru a PUR water canister,,, and use it for cooking & coffee,,, we have done that for years because we used to camp on our own land,,, where there was no water available,,, we also @ that time used it to make more Ice,,, because it took over a hour to go to a store and back !!!
Waste Not,,, Want Not !!!
Old 02-26-2016, 07:54 PM   #48
The Factory filter also "Filters" all water from City Inlet,you might want to rethink Removing the Filter as it keeps "Things" out of faucets,toilet valves,ect. Youroo!!
Old 02-27-2016, 06:57 AM   #49
If we ever have to add water,,, we carry a filter to hook to the hose outside,,, I always filter all water before it enters the MH... nothing wrong with double filtered water !!!
Old 02-27-2016, 08:01 AM   #50
Chewie's Avatar
Are these canisters breaking only during freezing months? I understand the bypass mod, but I guess my question is are they breaking under normal use on city water?
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
Chewie is offline   Reply With Quote
water, water filter
