Old 02-18-2016, 02:09 PM   #1
Broken water filter canister
So somewhere along the way in my winterization steps, I apparently neglected to get all the water out of canister that holds my water filter out. I did remove and discard the actual filter, left the canister empty but screwed back on. Today I went to "un" winterize for a weekend trip and discovered the canister cracked wide open. I think I know the answer to this but...does this mean I can't use any running water inside my rig since all the water gets filtered through that canister and there is none there now?
jeffreymhardy is offline   Reply With Quote
Old 02-18-2016, 02:13 PM   #2
A32Deuce's Avatar
Unless you bypass the filter housing, No! You can just buy the part that split. Must dry the housing before putting back together.
A32Deuce is offline   Reply With Quote
Old 02-18-2016, 02:21 PM   #3
Thanks Deuce...I actually found a couple people who had the same thing happen, not because of freezing temps but because of the way the filter housing is attached. I'll see if I can figure out how to bypass it.
Old 02-18-2016, 10:10 PM   #4
Did you blow your system out? I was lazy one day but new the temps where dropping fast. Pulled the filter and blew everything out. Next weekend went to pump antifreeze in the lines and the filter was almost full again. I was almost content leaving it blown out. Glad I decided to use antifreeze.
Fozzy is offline   Reply With Quote
Old 02-19-2016, 09:23 AM   #5
I did my first de winterizing last night to get ready for this weekend. Are there any tips I should be aware of to prevent this from happening?
Airbornemp is offline   Reply With Quote
Old 02-19-2016, 09:32 AM   #6
KyDan's Avatar
I'll admit I'm not familiar with your exact set up but.... over the years this
comes up here over and over!
Many folks permanently bypass their on-board water filter and use an
external one. IE: one that is connected to the fresh water hose
at the spigot or at your outside city water connection.
Think what would have happened if your filter had cracked while the city
water was on and you were away!
Plus you don't have to worry about spilling contents and making
a mess inside when you're winterizing or changing the filter.
My 2
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 02-19-2016, 09:39 AM   #7
That's a good idea...I don't want to have to worry about this next winter.
Old 02-19-2016, 09:43 AM   #8
fonzie's Avatar
Lots of people remove water filter and use it outside instead.....including me
semi permanent removal of water filter
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 02-19-2016, 09:51 AM   #9
Water filter crack
In our RV, blowing out the lines will not empty the filter canister. We must blow out the lines THEN empty the filter canister.
dmax36 is offline   Reply With Quote
Old 02-19-2016, 09:54 AM   #10
dmax36: I did what you said, and I still ended up with water collecting in the bottom (apparently) of that canister. Obviously I did not blow the whole system completely out. I'm just hoping nothing else got damaged that I don't know about yet. I'm camping now, but not using water since I had no easy/quick way to bypass that canister and test it.
fonzie: That's a great idea and thanks for posting the link for me
water, water filter
