04-14-2016, 08:24 AM
geezer with gadgets
Built In TPMS
Purchased a car to use on our tow dolly that has a built-in TPMS in each tire. My question is (and I tried to search, but no luck), can I add 2 TST 507 sensors to the rear tires of the car?
I already have them on my Sunseeker and the tow dolly. Don't want to screw up anything with the car's original sensors.
Thanks for your help...
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 57 2019: 30
04-14-2016, 08:54 AM
Yes you can.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
04-14-2016, 08:55 AM
Assuming they operate on different frequencies, and they probably do, you will be just fine!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
04-14-2016, 09:02 AM
geezer with gadgets
Originally Posted by Kenny kustom
Yes you can.
2016 Sabre 36QBOK
Thanks this is helpful.
Days camping (2015)----88 days
Days camping (2016) ---67 days
30 years RV'ing
12 different RV's
And thank you too, RSchleder
FRF Rock!
04-14-2016, 09:33 AM
Frequency of a sensor must match the frequency of the module however, each sensor sends out a unique identifier. This identifier is programmed into the module. I believe there are only two frequencies used by vehicle manufacturers, 315mhz or 433mhz.
Example, if you have two 2015 Silveradoes parked next to each other, the tire sensors are all on the same frequency; however, the computers in each vehicle only recognizes the identifier of the sensors that were programmed to the vehicle.
Years ago, we actually programmed the sensors from two tires of one Hummer H3 (A) to another H3 (B). Hummer A still had the four sensors programmed into the system, and Hummer B had the sensors from Hummer A programmed along with two sensors on Hummer B. So you can program a sensor into more than one system, but you could not program more than four sensors into a system; it was limited to four sensors. Spare tire was never monitored.
04-14-2016, 10:01 AM
geezer with gadgets
Lots of good information here, too!
