Old 08-25-2012, 05:11 PM   #1
bump
When camping this week, the sun hit the side of our Sunseeker and I saw a bump under the window of the front. (above the cab) It is looks like the reverse of a dent if your car was hit by a softball....Now when I look at that side that is all I see. It worries me is there something I should be doing about it. When I pushed on it is has no give. It only protrudes about 1/2 inch.
We camp on earth with a Sun Seeker 2300
yworrydog is offline   Reply With Quote
Old 08-27-2012, 08:39 AM   #2
GM
bclemens's Avatar
could be a weld spot that was not quite ground down all the way? Unless it gets bigger, there shouldn't be much to worry about. Could you pull the window if need be to take a look? Is it close enough to the edge?
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
