Old 10-26-2013, 05:22 AM   #11
Ford Idaho's Avatar
Originally Posted by MotocrossCamper View Post
There is only one on a Sunseeker, at least the 04 thru 06. Attachment 41717
I'm just not sure if that carried through to 08
Which way do you need to have it turned to bypass?
Old 10-26-2013, 06:27 AM   #12
Herk7769's Avatar
Originally Posted by RamblerGuy View Post
The photo I posted shows the valve arrangement on our 2011 Sunseeker.
I'm puzzled by the single three-way valve that Motocross posted. Does the tee on the hot water outlet line have a check valve in it? If not, then water and/or antifreeze would enter the water heater through the hot water outlet.
The single valve system has a brass check valve at the hot water outlet that prevents the pink from entering the hot water tank.
Turning the valve handle so it points UP will divert the incoming liquid into the vertical bypass pipe and isolate the tank.
The 3 valve system requires closing (turn 90 degrees in either direction) the top and bottom valves and open the bypass valve in the vertical pipe.
ID:	41776   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 10-26-2013, 07:02 PM   #13
MotocrossCamper's Avatar
Like Herk said, to bypass it should point up. If you can zoom in in my picture I have it wrote in marker.
MotocrossCamper is offline   Reply With Quote
hot water, water
