Old 06-06-2018, 08:35 AM   #1
Cab ac in class C
Our AC is not blowing air from the dash. It is blowing through defrost and floor area. What could be wrong. It is a forest river sun seeker 2012 Class C 31.5ft with 13,000 miles.
Sshlinda is offline   Reply With Quote
Old 06-06-2018, 08:43 AM   #2
grumpy0374's Avatar
You have a leak in a vacume line somewhere in the ac system. The defrost is the default where air will be diverted when there is a leak.
There are plastic vacume lines under/behind dash and in engine compartment.
The only ones that are readily accessable are located on the passenger side footwell area. If you can look up under the dash to the far right next to and up from the plastic kick panel you'll see a few plastic vacume lines. If your lucky, it will be one of these lines that has a crack or has come loose. Lucky because these are the easy ones to get too. Rest require partial dash removal, removing dog house, removing battery to access firewall to trace lines, ect. It could also be a crack or damaged plastic fitting that the vacume line attaches too that connects the line to the engine or the ac system. Can be a real bit-h to find.
Had the same problem last May on the road. Luckly found a crack in a line where I advised you too look first. Local auto parts store I found (Auto Zone) had a small vacume line repair kit, a few bucks, that had several pieces of thick wall rubber tubing to act as a splice. Different diameter pieces. Cut damaged piece out and spliced it togather. Hit the road and as soon as air started into system, it blew normally.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 06-06-2018, 09:32 AM   #3
Total Loss's Avatar
Ford's still have vacuum operated blend doors?
Wow- I just looked it up- my Chevy does also.
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
Old 06-06-2018, 09:41 AM   #4
grumpy0374's Avatar
Yup, still using 1960's technology. And, they can be a pain to trace down.
When there is a leak in a line, the blend door/s remain closed and any air is automatically diverted to the defrost vents. At least on the Fords. Not 100% sure about Chebbies.
Grumpy
Old 06-06-2018, 09:52 AM   #5
Ford also uses a vacuum system to engage the 4wd in their F150. Search IWE failure and you'll get a lot of reading.
Essentially the hubs try to engage on their own due to vacuum loss - which makes a grinding noise in low vac loss cases, or makes it sound like somebody through a bucket of bolts in a blender when it ends up being a steep drop in vacuum pressure.
Happened 2x to my F150. Dumped it at 14k miles. Didn't need it anymore anyway since we bought the motorhome.
2020 Rockwood Mini Lite 2509s
2019 F-150 3.5 EB SCREW Max Tow - 1797 payload
s1njin is offline   Reply With Quote
Old 06-06-2018, 01:26 PM   #6
That would be a Ford problem not Forest River.
2014 SUNSEEKER 3010DS
TOADS, 2012 FOCUS OR 1998 JEEP WRANGLER,
Kevin & Judy is offline   Reply With Quote
Old 06-06-2018, 02:26 PM   #7
Duckogram's Avatar
No, thats a sshlinda problem because its a 2012.
ILB ( | )
Old 06-06-2018, 03:36 PM   #8
A32Deuce's Avatar
You can buy a repair manual for an E350/E450. I did and it helps with the chassis/ Ford.
A32Deuce is offline   Reply With Quote
Old 06-06-2018, 05:08 PM   #9
A32Deuce's Avatar
You might be able to borrow a smoke machine and find the leak that way.
Old 06-06-2018, 08:25 PM   #10
HerveVR's Avatar
Sshlinda,
When the A/C is malfunctionning out the front dash, while on the road, you can run your generator and get the «house A/C» cooling the place.
But, get sure not to drop under 1/4 fuel tank.
HerveVR is offline   Reply With Quote
class c
