Old 12-18-2012, 09:27 PM   #1
Cab Dome Light Switch
Is there a way to turn on the inside cab dome light rather than opening the door? I could not find a switch.
2013 Forest River Sunseeker 3010
RVFamily5 is offline   Reply With Quote
Old 12-18-2012, 09:50 PM   #2
DangerCliff's Avatar
I just bought a 2013 , 2860 on a Chevy and I think on mine its on the dash light dimmer swtich. Do you have a Chevy or Ford ??
DangerCliff is offline   Reply With Quote
Old 12-18-2012, 10:31 PM   #3
I have a 2013 Sunseeker 2860 with the Ford V-10. On the Ford, the guage dimmer control is just to the left of the steering wheel, between the steering column and the headlight switch. Just turn up the guage dimmer control to maximum and the cab light will go on.
And to DangerCliff. I too have the 2860, not to hijack the thread, but what does your "A, B, Both" switch on the right as you enter the coach walking up the steps do? Mine has no effect on the radio or TV.
KQ2N is offline   Reply With Quote
Old 12-18-2012, 10:55 PM   #4
KQ2N the A B seems to turn off the rear speakers when the T V is on.
And one for you ,Is it true what looks like a sewer drain hookup out side of the compartment just behind the rear wheels is the fresh water drain ?? Also does your living room slide not close as tightly at the top as at the bottom ? Mine on top is about 1 to 11/2 inches from from being closed.
Old 12-18-2012, 11:02 PM   #5
My speaker switch isn't working evidently... The drain behind the rear wheels is the gray water drain for the outside sink. Let me check the slide tomorrow when it's light outside.
Old 12-18-2012, 11:03 PM   #6
The AB switch controls sound from the speakers. In A sound comes from the front cab speakers (in the door panel on a Chevy) and the rear ceiling speakers. In the B position, sound comes from the speakers in the ceiling of the cab over bunk and the rear ceiling speakers. In A+B the sound comes from front cab and ceiling speakers (and rear ceiling speakers).
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 12-19-2012, 09:34 AM   #7
GM
bclemens's Avatar
Also, there is a setting on the radio (in the equalizer section) that lets you turn on the center speaker. This is typically only on in 5.1 surround.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 12-19-2012, 10:36 AM   #8
Danger Cliff - Both my living room and bedroom slides close quite tightly and uniformly top to bottom. About 3/8 inch on the bottom and 1/2 inch on top, so just 1/8 inch difference from bottom to top.
I just tried the A/B speaker switch again. Yes, on the radio screen I can switch between front, rear and even center speakers and variations in between, again all from the radio screen, but the A/B switch has no effect whatsoever regardless.
Does the A/B switch button pull off so I can take the plate off and see what's going on with the wiring in the switch? It's on warranty, so I don't want to break it, nor do I want to drive it 140 miles one way to the dealer to fix it.
Old 12-19-2012, 11:52 AM   #9
KQ2N I can't help you on the switch as my coach is not kept at my house. Thanks for your help on the slide out question. If you ever get out to Tucson Az area let me know. It would be fun to meet you and to compare coaches
Old 12-19-2012, 05:25 PM   #10
Thanks. The dash dimmer switch did it. I was looking for another switch. Thanks again!
