Old 12-31-2015, 10:01 AM   #11
A32Deuce's Avatar
Your converter is fused on both sides. You need to find the converter and check the fuses. If they are not blown, then you have to see if the converter is getting power. If not then you may need a new converter. Plugged in to 110 and dim lights means your converter is not putting out 12 volts.
A32Deuce is offline   Reply With Quote
Old 12-31-2015, 11:43 AM   #12
I have a 2300 as well. Can you tell me if the main battery switch in the door well has to be on for the batteries to charge when on house power or when the truck is running? I am new and had no walk through with the original owner.
canadave is offline   Reply With Quote
Old 12-31-2015, 12:11 PM   #13
bubbles's Avatar
That is a requirement (batteries not disconnected when on shore power) in my Georgetown and I believe also in the Sunseeker and all Forest River MH's. I'm not 100% sure with engine running but I think yes.
Old 12-31-2015, 12:12 PM   #14
That was my thought also. Glad you confirmed it. The dealership is closed til Monday so this snowbird is grounded. Last time I used it (plugged in) the lights would brighten, then dim. I would hear a click down by the step. Just yesterday I was feeling smug because I've never had any problems. Oops!!
Maggiewaggie is offline   Reply With Quote
Old 12-31-2015, 01:39 PM   #15
A32Deuce's Avatar
Switch has to be on when on shore power or engine running.
Old 12-31-2015, 02:29 PM   #16
Your converter should have 2 fuses in the back part of the converter check those? if the fan in the converter isn't working then you need a new converter, I had the same problem, my just had to replace the fuses, if your fuses keep browning out then get yourself a new converter..Good luck & Happy New Year..
goots is offline   Reply With Quote
Old 01-01-2016, 09:19 AM   #17
Hoglou's Avatar
Two comments:
- you changed batteries, I wonder why and what did you install?
- open the passenger side rear storage door and look on the top left side of the shelf, that is where the 120v to 12v converter is. you should hear a fan running under load. if no sound is heard but the fuses are bood a possible cause may be a a dead converter as the venting hole into the underside of the bed is of minimal size and may cause a shorten life of the unit.
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 01-01-2016, 11:48 AM   #18
Found one fuse on the converter, it was OK. Can't find # 2.
I replaced batteries because the dealer sold me a unit that had batteries with holes knocked in them that had been patched. Beginning to leak, Could have had a fire!
I replaced them with two very large batteries from Sams club.
Yes, I used to hear the fan cycling, not now.
Thanks for the great info!
Old 01-01-2016, 07:46 PM   #19
Garrette's Avatar
I think the fan is set to thermal protection. I have a new Progressive charger and have never heard the fan. The old WIFCO, yes but not the progressive. May be location. Mine is located next to the wet bay. Probably cooler.
Garrette is offline   Reply With Quote
Old 01-02-2016, 04:19 PM   #20
Suffering through the same problem. Tried c/b's, checked fuzes , cycled every breaker/ switch I could find and still nothing out at the batteries. If you solve it, please post how. If we do, will do the same.
geri
Geri is offline   Reply With Quote
