Old 04-21-2015, 10:01 AM   #11
GM
bclemens's Avatar
What you have on the table should make an "H". The top and bottom horizontal bars stay there.
Installed those two angles vertically one on each side and then the square bracket mounts to those. TV mounts to the square bracket. If the holes don't line up, we probably drilled them as needed.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 04-21-2015, 04:35 PM   #12
Originally Posted by malagusta View Post
I thought about that also but the holes on the plate don t match with the tv holes.I guess I will have to find a dealer here and see if they have any idea.It has confounded my friends here too,and one guy is good at puzzles.Thanks for the input.When I get it figured I will post results.Again thank you for the help.
Possibly the replacement TV has different hole spacing. Unless it is exactly the same make and model TV it may be different. If the bracket will work otherwise and position the tv correctly in the cabinet just go ahead and redrill the holes to make it fit.
ATVer is offline   Reply With Quote
Old 04-21-2015, 06:26 PM   #13
Dealer gave me wrong tv.Got TV from in house holes matched perfectly put in space but square bracket is 3 inches too short.Small holes on horizontal angles match small holes on small holes on rectangular bracket.The 2 angles he sent are the ones that are already installed in space.The 2 angles he sent threw me.Now just have to get longer rectangle.Thank you again for help.
malagusta is offline   Reply With Quote
