Old 10-31-2014, 06:26 PM   #1
Smile camping tonight will it freeze
I am camping tonight and the temp is going down to 20 can i keep my water in the camper? thank for any help Dale. I have a 3010ds
bikeit02 is offline   Reply With Quote
Old 10-31-2014, 06:42 PM   #2
coupevillefish's Avatar
I think you will be OK. Unhook the outside hose, keep your heat on.
coupevillefish is offline   Reply With Quote
Old 10-31-2014, 06:54 PM   #3
I am going to insulate the drain hose and try it. Dale.
Old 10-31-2014, 06:55 PM   #4
B and B's Avatar
Tank heaters on if you have them, do make sue you run your furnace and not just electric heat. In My trailer the furnace vents in the basement and the pipes actually follow the water pipes to the kitchen across the fresh water and galley tanks.
Brian
Old 10-31-2014, 07:18 PM   #5
I'd suggest draining sewer hose and putting it away. If there's liquid in a low spot that freezes, thawing would be a pain. Leave liquid in the tank.
We were in our 3100 at 19 degrees with 20 mph wind fully exposed and had no problems. Compartments with water pump and sewer hookup stayed about 50 degrees with furnace at 65.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 10-31-2014, 07:56 PM   #6
Ret E-9 Anchor-clanker
donanddona's Avatar
I've weathered 15 deg but the water hose did freeze and split. Better to remove and drain for further use. Disconnecting the sewer is a good idea too.
donanddona is offline   Reply With Quote
Old 11-04-2014, 11:47 AM   #7
We camped last weekend the temperature went down to 18,we ran the furnace for heat.The inside water system worked and did not freeze there was little wind my lp tank went from 2/3 to 1/3 in one night.we drained and moved out when the temps where in the 30s.I am glade that we had no problems.
Old 11-04-2014, 03:50 PM   #8
hockeytownmom's Avatar
I decided spur of the moment to take the kids out last night since they don't have school today, luckily we didn't hit the freezing mark this trip!
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
Old 11-04-2014, 04:28 PM   #9
Alleged curmudgeon
Vern's Avatar
I think some of these answers may be assuming you are talking about an overnight freeze that is isolated to a period of several hours. If the temps are not going to rebound tomorrow, further precautions may also be indicated.
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34); 2018 (39); 2019 (22)
Vern is offline   Reply With Quote
Old 11-05-2014, 08:02 PM   #10
wesslvm's Avatar
Little operating experience for you... Don't rely on the LEDs for propane tank level, always double check the tank mounted gauge. I once ran out with 1/3 still indicated. 😱
2014 Sunseeker 3050S
Honda CRV (TOAD)
wesslvm is offline   Reply With Quote
camping
