Old 08-30-2016, 10:02 AM   #1
Can see light around slide outs
When my slideouts are full retracted I can still see some light coming in at the corners. I'm concerned because I figure if light can come in, water can come in. I haven't had any issues (that I'm aware of) with water coming in. When the slides are fully in, is that supposed to be a complete seal? My motorhome has 3 slides, and they are all like that.
dbareford is offline   Reply With Quote
Old 08-31-2016, 11:55 AM   #2
One of my early projects was to run the slide out, then inspect & correct all the seals. There was several spots that water could have flowed in, but with some simple mods and sealant here and there, all has been corrected.
If you can see light with a fully retracted slide, you should examine the areas & make corrections if possible. Else, run it back to your dealer & demand it be fixed.
2016 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
brucemc is offline   Reply With Quote
light, slide, slide out
