Old 10-18-2013, 05:24 PM   #1
Sunnyfun's Avatar
Can't get water filter canister off - help!
Ready to winterize our new 2014 Sunseeker 3050, can't get the water filter canister off no matter what I have tried. I have the plastic wrench that was given and have also relieved pressure nothing works. I think maybe Arnold S. Must have put in on. Any suggestions ? Thanks
Sunnyfun is offline   Reply With Quote
Old 10-18-2013, 06:02 PM   #2
Phat Phrog Stunt Crew
awwall's Avatar
Sometimes it just takes brute force. You may want to hold the mounting bracket and just put the muscle to it. If you get it off, when you put it back, lube the o-ring and the threads with silicon grease. Next time will be much easier. Remember to do the Threads!!
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 10-18-2013, 06:04 PM   #3
If you are facing the canister, put the wrench on the right side and pull toward you. Make sure you are holding the base(top) to keep from breaking the base. When you get it off, make sure you get some Danco Silicone grease (Lowes/HD) and lube the "O" ring and the base and the top of the canister and the threads on the base and canister. Next time will be much easier.
See awwall types faster than me.
Old 10-18-2013, 06:55 PM   #4
Sunnyfun's Avatar
Thanks to both of you, I guess all I can do is keep trying, stopped for now and will try again tomorrow. It's just a little frustrating when you thought your winterizing would be done on one day. Will be sure and get the lubricate on your advice, don't want to go through this again. Thanks again l
Old 10-18-2013, 07:05 PM   #5
Once you get the filter housing off, mark the direction with a sharpe. Put an arrow on it so you know which way is OFF next time. Counter clockwise is OFF.
Tim
2013 Forester #3051SF
2009 Toyoda Tacoma (toad)
2010 Newmar Dutchstar (Sold)
2011 Fleetwood Bounder (Sold)
trwmodela is offline   Reply With Quote
Old 10-18-2013, 07:40 PM   #6
Fulltime family RVer
Sorry for the thread rename. I'm a dunce.
Old 10-18-2013, 07:40 PM   #7
Mine is clockwise for off if viewed from the top, front or bottom it has rh threads.
Right-Tight; Left -Loose.
Old 10-19-2013, 08:04 AM   #8
For issues like this I have found heating the thread area with a heat gun sometimes works. Another option is a moderate smack on the wrench handle with a rubber hammer or piece of wood will break it free.
ATVer is offline   Reply With Quote
Old 10-19-2013, 11:14 AM   #9
Sunnyfun's Avatar
Thanks for all of the advice, we have tried every which way and nothing seems to work, hoping to have winterizing all behind me yesterday, but, didn't work out, everything was ready to go until this roadblock. I guess I will have to call FR since my dealer is 300 mi. away, even tho they are the ones that put it on to begin with. Just bought this motorhome in Aug. But, thanks again I will let you know how it turns out.
Old 10-19-2013, 11:21 AM   #10
I imagine you could find a Mobile RV Tech in your area to take care of it. It might be cheaper to just break it off and replace it however.
