Originally Posted by kitejunky1
Outside and along the sides and corners. Thanks for your time
I use some from Ace Hardware to seal my lights and around my cap I think it is called 3006, It holds up well without shrinkage. You can really use any that you like, except for the roof penetration. Then you need Dicor I think it's called. I asked at the rally what caulk they where putting on, and they said just regular caulking. But I find that the 3006 is easy and cleans up nice when you go over it with a wet sponge. It's a Siliconized Acrylic Latex caulk. Never had a leak at any seems or lights. Hope that helps you easy to find and won't dry out in the tube if you put some tape over the end... It will come in white and tan. Also will not mildew on you. I just went an got a tube it's called White Lightning All Purpose adhesive caulk. And it is cheap compared to Dicor per tube.
