01-06-2015, 04:51 PM
Ceiling speaker cover removal??
Does anyone know the proper way to pop the cover off of this ceiling speaker from a 2014 Sunseeker 3100? I've tried various prying methods but don't want to break anything. Also, who would be the manufacturer of this speaker? Thanks.
01-07-2015, 05:12 PM
Love My Sunseeker
I had to have a loose wire repaired in one of my speakers, just like yours. The RV dealer said it's an easy pop off. May have to cut the seam with a knife, but easy to pop back on.
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
01-07-2015, 10:42 PM
I'm not too enthused about cutting anything with a knife. There would surely seem to be an easier, lass potentially damaging way to get the cover off. Thanks for the reply.
01-07-2015, 11:00 PM
Commercial Member
I just saw a cover off today...ran out of off white and are subbing white. Seems there was a tab at each long end that pried off. I'm flying to the Denver RV show tomorrow or I would confirm in the morning.
01-07-2015, 11:17 PM
So, I should pry on both ends at the same time from the ceiling down? Hmmmm, I'll check that out. BTW, Brian,would you be coming to the Tampa, Florida RV Supershow next week?
01-08-2015, 05:30 PM
I tried for several minutes to pry the covers off in my 3010 with no luck. I finally said hell with it and popped them off with a screwdriver, breaking the tabs in the process. It doesn't seem there's any easy way to get them off. In my case it really didn't matter as I was replacing them anyway.
Rod & Carla B.
The Hounds Kooper & Abby
2022 Fleetwood Bounder 35K; '18 Ford Focus toad
Owned 2015 Sunseeker 3010DS previously
01-08-2015, 10:02 PM
Originally Posted by raoulwv
I tried for several minutes to pry the covers off in my 3010 with no luck. I finally said hell with it and popped them off with a screwdriver, breaking the tabs in the process. .
So, is there tabs on the cover that fit over ear-like projection nubs on the base? Are they on both far ends, do you remember? Do you still have them?
01-09-2015, 09:53 AM
If I remember correctly, there were tabs on all sides of the cover, which is what made it so difficult to remove. I don't remember now if I actually broke the tabs or just really chewed up the plastic cover with the screwdriver.
I don't still have them. I threw them in the trash, which is where they belong IMO.
Rod & Carla B.
01-09-2015, 11:15 AM
Love My Sunseeker
Yes, you do prop off with the tabs, but you have to cut the seam. That's why you couldn't get it off. I can now see the difference between that speaker and the other speaker that hasn't been removed yet, but it's subtle.
01-09-2015, 11:43 AM
I just popped mine off with a screwdriver but it left very small marks which I filed down with a nail file. I did not have to 'cut the seam' and I saw no signs of any sealant on the seam when I got it off but could be different for others.
Here is a trick I should have used and will next time., Heat it up pretty warm with a hair dryer. Even getting a lens off the ceiling lights goes better if you get it good and warm.
01-09-2015, 12:55 PM
Everiddie,
I like your trick.
Thanks for posting it.
2012 Rockwood Windjammer 3008 W
2020 Tundra Dbl Cab 4X4 SR5
01-09-2015, 04:58 PM
For most plastic tabs I use the hair dryer and a couple of the hotel room keys (thin credit card) to slide the tabs in. I have applied this trick to the spearker as of yet.
Hoglou the DH & BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
01-09-2015, 09:24 PM
OK, so a hair dryer, 4 panel pullers and 4 hands. Got it. Thanks everyone.
01-15-2015, 09:33 PM
Well, I tried again today to pry speaker cover off with no success. I really don't want to damage the ceiling around the cover by prying against it. There has to be a way to get these off............
01-15-2015, 09:50 PM
Nooo, you are prying at the wrong part. You shouldn't need to touch the ceiling. You pry at the line or goove you see. It is a good quarter inch away from the ceiling.
01-15-2015, 10:21 PM
That's what I didn't know. OK. I was always wondering if that was the separation line but no one had specified that. Thanks. I'll work it from that angle.
01-30-2015, 05:38 PM
Commercial Member
not sure why all the fuss. My speaker covers come off with little or no effort using a small pry tool.
01-30-2015, 05:52 PM
^^^ That's a good one. might have to go that route. I haven't tried lately, but now that I know they separate at the dividing line, maybe I'll have better luck.
02-04-2015, 11:10 AM
Love My Sunseeker
And one more time, there is a "seam" around those speakers. You have to break the seam.
