Old 10-26-2015, 07:55 AM   #11
Send a message via AIM to jk31668
mine came with some paper tags on the cover that said it has 15w40 installed.
2010 sunseeker 3100ss
jk31668 is offline   Reply With Quote
Old 10-26-2015, 08:03 AM   #12
Citrus County, Fl.
GL1800Rider's Avatar
Originally Posted by trdutch View Post
Compression washer sounds like a better option to me.
Honda Goldwings all use the "crush washer" and I guarantee you will never see a drop of oil under a Goldwing.
10 Pack of Crush Washers - Honda Gold Wing Parts & Accessories by WingStuff.com
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 10-26-2015, 12:56 PM   #13
oldgold's Avatar
X2. We use 15w40. Depending on operating ambient temps... I believe straight 30 weight or 10w30 are acceptable per the manual.
2015 XLR Nitro 30FQSL
2015 F250 King Ranch
oldgold is offline   Reply With Quote
Old 10-26-2015, 02:05 PM   #14
rbetzwieser's Avatar
Couple questions
Other than Dino 10w30 that Tito used in the Video,any other recommendations on oil?Someone once told me Onan gen sets use a specific oil.
We are fair weather campers in the south
Also Tito in the video used a thread sealant on the drain. I've never heard of using this.Wouldn't there be a possibility of contaminating the oil?
Correct, I would not use tread sealant. It will contaminate the oil. Never used it on mine and it doesn't leak.
rbetzwieser is offline   Reply With Quote
Old 10-26-2015, 03:17 PM   #15
I changed over to full sunthetic last time
Old 10-26-2015, 05:42 PM   #16
oldgold's Avatar
I was told by the head Cummins/Onan mechanic not to use synthetic, I wild have thought it would be better. He said the molecules were smaller and more able to make their way out of the system. Not sure how true all that is, but I would check your oil level often just in case he knew what he was talking about. He said a high end 15w40 regular oil is the best option with straight 30 weight a close second.
Old 10-27-2015, 06:31 PM   #17
Total Loss's Avatar
I've used teflon wrap on every drain bolt on every oil change I have done...
Several hundred in many vehicles.
I have never had a leak and have never hurt an engine- any type.
And I never buy new washers. Just be careful.
Don't over use it and it won't get into the crankcase.
Nobody changes my oil but me. (except on my company car- it's theirs)
Over 35 motorcycles and ATV's, cars, trucks, gennies, lawn equipment- anything with a motor.
25 oil changes just on my wifes last car.
Total Loss is offline   Reply With Quote
