Old 06-15-2019, 01:11 PM   #1
Charger lights not working
I have a 2014 Sunseeker 3050s and my running lights /plate light doesnít work. The brakes and hazard work fine. I tried checking all the fuses under the drivers compartment and they all seemed okay.
Any suggestions? Iíve seen folks mention checking the ground, but Iím not sure where that is.
Thanks!
SunseekerCurt is offline   Reply With Quote
Old 06-20-2019, 10:39 PM   #2
Garrette's Avatar
The side marker lights are on the same circuit as the tag light. If memory serves, the fuse is a 15amp fuse #10 in the fuse box behind the parking brake pedal.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 06-21-2019, 08:44 PM   #3
Fuses are okay
I checked all the fuses in the box under the pedal and they are okay. Any other suggestions?
Old 06-21-2019, 11:14 PM   #4
Garrette's Avatar
I am referring to a Ford chassis. If yours is a Chevy, than my info is wrong.
After checking, it is fuse #22. I would pull the fuse and look at it. If the fuse is ok, I would check the bulbs. I am just guessing.
This is for a 2013/2014 Ford chassis owners manual.
It could be a ground problem. But all I can think of is the battery ground. There may be a separate ground for the accessories but I would not know where.
With a Volt/ohms meter, you could do continuity checks on the wiring.
Look under the RV for any loose or dangling wiring. Maybe others will have additional ideas.
Keep us posted.
ID:	207931   Click image for larger version
Old 06-22-2019, 11:43 AM   #5
Still no luck
All the fuses look good. Iíll have to see if I can chase down the ground wire. Thanks for the help.
Any suggestions would be appreciated.
light
