I am referring to a Ford chassis. If yours is a Chevy, than my info is wrong.
After checking, it is fuse #22. I would pull the fuse and look at it. If the fuse is ok, I would check the bulbs. I am just guessing.
This is for a 2013/2014 Ford chassis owners manual.
It could be a ground problem. But all I can think of is the battery ground. There may be a separate ground for the accessories but I would not know where.
With a Volt/ohms meter, you could do continuity checks on the wiring.
Look under the RV for any loose or dangling wiring. Maybe others will have additional ideas.
Keep us posted.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
