Old 07-28-2014, 03:05 PM   #1
Charging via 110 outlet
Hi folks you have been very helpful in my previous posts. Thanks. I have been charging my 3170DS using a extension cord. The other day I turned on the AC for about an hour. The cord became very hot. My question... what type of extension cord should I use (guage) and length. Is it okay to run the AC on 110 or should it only be while engine or generator is on? Thanks in advance.... hope you are enjoying the summer.
Sent from my SM-T320 using Forest River Forums mobile app
scoto is offline   Reply With Quote
Old 07-28-2014, 03:15 PM   #2
Brother Les's Avatar
Your unit is set up for either 30 Amp or 50 Amp. Is the 110 coming from your house either of these? Most house 110 outlets are 15 Amps. I believe that you are putting a large amount of strain on the AC unit if your 110 is only 15 Amps. The cords will get hot (and bad things may happen). Can you install a 30/50 Amp and wiring from your breaker box for you motor home
I never run my AC when I am plugged in to 110 15 Amps. I would not encourage anyone to do so with lower Amperage.
Brother Les
Old 07-28-2014, 08:09 PM   #3
Denver, CO
garbonz's Avatar
X2. AND if you do decide to upgrade your power, MAKE sure it is done correctly. 10 gauge 2 strand plus ground for 110 volt 30amp breaker. 8 gauge 3 strand plus ground for the 50 amp 220 breaker. If you do them wrong you will fry stuff.
2017 Fuse 23T
Old 07-28-2014, 09:34 PM   #4
Don't run the AC on a standard extension cord as it will yield low voltage to the AC (result of the cord getting hot) and stress the AC compressor motor and burn it out. Kind of surprised your house circuit breaker didn't trip. Wiring in the house on that circuit probably got hot too.
ATVer is offline   Reply With Quote
Old 07-28-2014, 09:39 PM   #5
Tailwind's Avatar
If you have a 20 amp circuit, you can safely run 1 air conditioner on that. You will need a 12 guage extension cord no longer than 50 feet. 25 foot would be better it will reach.
2012 F-250
Flagstaff 8528IKWS
Tailwind is offline   Reply With Quote
Old 07-29-2014, 10:10 PM   #6
I run mine from time to time when cleaning it getting ready for a trip. I would guess you are using a cheap, old or to long of a cord. I use a 25' construction grade 12 gauge cord and is never hot. I have a 3170 as well and believe the ac pulls 12amps. On a 20 amp outlet I would think you would be fine as long as you aren't making toast at the same time. I don't know if that's the correct answer but I do it quite often and works fine
rdeiss is offline   Reply With Quote
Old 07-29-2014, 10:39 PM   #7
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Don't forget the converter/charger, it will attempt to charge the house batteries and easily draws 5 - 10 Amps AC, ours draws up to 15 Amps.
A 15000 BTU air conditioner draws ~20 Amps on startup and goes back to ~16 Amps when running plus whatever the charger uses for the batteries.
To play it safe you need a 10 awg. ext. cord (not to long) and a 30 Amp hookup including proper wire size. A power management system with power sharing option would also help but can get pricey.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is online now   Reply With Quote
Old 08-03-2014, 06:41 AM   #8
Garrette's Avatar
Call an electrician and install the plugin and while you are at it, call a plumber for a sewer drop. Never regretted the money spent.
Garrette is offline   Reply With Quote
Old 08-03-2014, 10:25 AM   #9
You just need a heavy duty cord. Assuming you're on a 20 amp circuit you should be fine just running the a/c.
I've ran mine for days on a single 20 amp circuit.
Your cord is obviously too small since its getting hot, its probably a 12 gauge wire.
With everything plugged in and the a/c running go check your breaker box, just locate that one circuit and see how warm the breaker switch is. Warm is okay, hot is not.
howzball is offline   Reply With Quote
charging
