Ok, so the cat is out of the bag and I think I may have damaged my OEM chassis battery due to inactivity over the winter/ AND my aftermarket alarm system drawing it down over time. I am away from home for long periods of time and my new Sunseeker 3050 sits in storage a month at time in between check ups.
If I cannot restore the Motorcraft, what kind of battery should I replace it with? Starting battery or a dual deep cycle?
Or someone answer this question- If I'm able to plug in to power at my storage, will that keep my chassis AND house batteries charged through the BIRD? And if so, do I turn off the isolator switch, or keep it on while I'm plugged in?
Solar battery tenders- Ok, I know about Deltron and Battery Tender, which one to I get to keep the chassis battery functioning? 1 Amp? 5 AMP?
Once I get this battery / storage problem solved I'll be on the way to Happy RVing
Thank you in advance for some input here
