Old 03-29-2011, 07:28 PM   #11
MotocrossCamper's Avatar
Originally Posted by Nursx2 View Post
Yikes...all I want to say ios Onan suggested 5w40 WHICH i CAN NOT FIND ANYWHERE....SO i MAY GO TO SYNTHETIC AS WELL. i AM GOING TO INSTALL A POWER INVERTER FOR THE LONG DRIVE TO nc THIS SUMMER. aNY THOUGHTS ON IF i SHOULD HOOK IT UP TO THE FRONT CAB BATTERY OR THE 2 REAR ONES. tHANKS
ps.. sORRY FOR THE CAPS...i AM A TYPING ILLTERATE AND CAN NOTTYPE WITHOUT LOOKING AT THE KEYS!
Thank you for the honest reply. Thats all I was looking for, what Onan suggest or what others have used. I have 3 Onans and all three manuals have had different oil weights listed.
If our motorhome is running it charges all the batteries, I don't think it would matter much if your just going to be using it while you are driving. If you will be using it while you are camping I think I would want it hooked up to the house batteries. Less likely to run them low and they will get charged by the generator also if you use it.
MotocrossCamper is offline   Reply With Quote
