Old 06-17-2013, 07:54 AM   #1
Coach Battery Charger
I have a 2013 Sunseeker 2860, since I dry camp about 90% of the time, keeping my coach batteries at an optimal charge level is a prime concern. I realize 6 volt batteries in a parallel/series combination is the best way to go, but I have four 12 volt deep cycle batteries in parallel.
1) Does anybody know where the coach battery charger that runs off of the coach generator is located?
2) I read about "smart chargers", these chargers will not overcharge batteries and cause what's known as "sulfation". Does anybody know what charger is used in a 2013? Is it a smart charger?
3) Is the stock charger that comes with the Sunseeker 2860 sufficient to charge 4 batteries in parallel?
4) It seems that the engine alternator charger does a quicker job of charging the coach batteries than the coach's generator's charger.
As an example, I ran the 4 parallel batteries down to 12.0 volts last week as the heater was running during the night. Starting the Onan generator and running it for 2 hours didn't seem to fully charge them to the 12.6 volt level I was looking for. Driving home for the hour on the road with the engine alternator/charger charging them, did.
Thanks for any input.
Gary
KQ2N is offline   Reply With Quote
Old 06-17-2013, 09:03 AM   #2
GM
bclemens's Avatar
1. not sure, I'd have to ask.
2. The convertor uses the 3 stage charging which is good. We rarely see suffocation.
3. Yes
4. Correct. I will sometimes run the engine instead of Gen.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
