Old 03-06-2016, 05:17 PM   #1
Compartment door latches and locks,
Does any one know where to get the thin rubber gasket that goes between the latches/locks and the compartment door? Ours our splitting and pushing out, would like to install new gaskets when installing some new locks.
Kevin & Judy is offline   Reply With Quote
Old 03-06-2016, 05:25 PM   #2
Ford Idaho's Avatar
I would pickup a small roll of Butyl Rubber Sealant Tape like this.
American Hardware 30' Putty Tape, 3/4", Gray, #R-010B - Walmart.com
You may find it cheaper at a local hardware store or one of the big box stores.
Old 03-06-2016, 05:41 PM   #3
I have rolls of that stuff, might give it a try.
Thanks for the info,
Old 03-06-2016, 05:51 PM   #4
Ford Idaho's Avatar
Roll a bit of it up like you would plumbers putty and apply it to the latch or the door then just remove the extra that squeezes out.
It may last longer and seal better than the thin rubber stuff.
Old 03-07-2016, 05:59 PM   #5
O rings work well. Use a snug fitting one.
Frank
Frank & Brenda
Thor Windsport 27K TST 507 Tire Monitors
2012 Jeep Liberty Limited Jet 4X4, Hopkins TOWD light wiring, Blue Ox baseplate W/Ready Brute Hercules tow bar and Ready brakes
FrankMor is offline   Reply With Quote
Old 03-07-2016, 06:35 PM   #6
I replaced my cam locks with ones using a barrel key. They came with new gaskets.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
Teamfour is offline   Reply With Quote
Old 03-07-2016, 11:12 PM   #7
Delco Bobby's Avatar
What is the black sealant that they use inside the compartment doors? It goes around the perimeter of the opening and appears to be a weather sealant.
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
Old 03-08-2016, 10:12 AM   #8
The only problem with the barrel locks is you cant remove the key when its unlocked.
That means that you have to un-lock the compartment everytime you want to open it,
Old 03-08-2016, 02:55 PM   #9
Ford Idaho's Avatar
Unsure, could you describe it's texture?
Pro Flex RV sealant perhaps.
Old 03-08-2016, 04:00 PM   #10
It is a solid yet pliable compound that looks like black caulk but has more substance to it. It might be applied by a caulk gun or maybe an aerosol can.
There are places where it is a perfect bead and then there are some spots that are a bit of a mess.
I didn't see what a bead of Proflex looks like so I can't say yes or no.
ID:	101406   Click image for larger version
2018 Ford F-150
Old 03-08-2016, 05:13 PM   #11
Ford Idaho's Avatar
Could be, looks like what they used to seal the front storage on the lite.
Very firm but not brittle, sticks like ugly on ape when applied right.
Old 03-21-2016, 08:37 AM   #12
They came with the new locks.
I ordered new locks, and it came with the gasket
mnoland30 is offline   Reply With Quote
door, lock
