Old 03-16-2015, 07:33 PM   #1
Connections for gas line near propane tank ???
What /where can I get a hose with the right connections from the propane tank in my sunseeker?
I have a 3170. Sorry if my question is cryptic, just looking for this connection to run like a bbq pit.
2014 SunSeeker 3170DS
Ford F-450
drakethib is offline   Reply With Quote
Old 03-16-2015, 10:14 PM   #2
Look for an "extend-a-flow" from Marshall Brass. Something most any RV parts place should have. An "extend-a-stay" will also allow you to connect a propane cylinder (BBQ tank) to fuel onboard appliances if your MH tank runs low and you don't won't to drive for refill.
hotbyte is offline   Reply With Quote
Old 03-16-2015, 11:11 PM   #3
To further muddy the waters, there are also "Extend-A-Stay Deluxe" kits which offer the ability to connect a propane cylinder, as well as a grille at the same time. This can come in handy if you want a cylinder for cooking with a portable grille, but when you run out of LP gas from that, you can use the onboard tank.
mlts22 is offline   Reply With Quote
Old 03-22-2015, 08:31 PM   #4
Mine looks like a quick connect fitting for some reason
Ford F-450
Old 06-16-2015, 08:58 AM   #5
RETIRED
n-e-d's Avatar
OP was looking for a hose sounds like he has the factory outlet. Suggest you check with a dealer or Amazon has a 10' hose with quick connections
Mary and Me
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Cargo Van HR DRW EXT DIY Daytripper "My Little Red Corvette"
n-e-d is online now   Reply With Quote
Old 06-16-2015, 09:24 AM   #6
TGR
TGR's Avatar
Northern Tool sells a 10' hose for this connector, as does Amazon.
This connection is for low pressure propane and will only work with low pressure appliances or appliances modified to work with low pressure propane.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
TGR is offline   Reply With Quote
gas, propane, tank
