Old 01-28-2016, 05:30 PM   #11
TURBS's Avatar
Randy at best converter recommend this unit of progressive dynamics after I asked him which converter is best for boon-docking.
Hands down the "boondocker" it's named that for a reason ✌️
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 01-28-2016, 05:41 PM   #12
BendOrLarry's Avatar
I agree that the Progressive Dynamics with the charge wizard is the way to go. Had one in my last rig and I will be replacing my WFCO in my motorhome with one soon. We mainly boondock. It's takes more than a product with the "boondocker" name to convince me.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 01-28-2016, 05:53 PM   #13
Actually the microprocessor will revert from boost to normal after a period of time automatically to avoid issues. Of course, you can hit boost again to keep going. Strangely my Trimetric shows 14.5 volts applied whenever I am running the engine on the RV, so 14.5 can run for a long time with no serious issues.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 01-28-2016, 06:04 PM   #14
TURBS's Avatar
I guess I'd not take the word and advice of a guy who sells converters for a living.......
2015 Columbus 320RS
2008 2500HD Duramax
Old 01-28-2016, 08:36 PM   #15
MNtraveler's Avatar
Originally Posted by ScottBrownstein View Post
One advantage of the Progressive Dynamics line is that you can connect a pendant and FORCE the converter to go into boost mode. This means that if you boondocking and using a generator, you can maximize the few hours of run time to get as much battery charge as possible. The PowerMax does not appear to offer any manual control of charge level. If you aren't boondocking it really doesn't matter.
Since I have one of those, I'm curious how you do that.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 01-28-2016, 08:48 PM   #16
You buy the optional $12.00 pendent that connects via a data cable, then you can override the automatic cycles when needed. Google the converter and you will see this accessory.
Firestone airbags
Old 01-29-2016, 12:03 AM   #17
MNtraveler's Avatar
Thanks!
2016 Forester 2401R
Old 01-29-2016, 12:46 AM   #18
2015 Columbus 320RS
2008 2500HD Duramax
why are you selling it? what converter do you have installed?
poorbuthappy is offline   Reply With Quote
Old 01-29-2016, 03:09 AM   #19
Witch Doctor's Avatar
Originally Posted by AquaMan View Post
What happens if you forget the boost mode is on, since it is manual, and you run a long charge? Will it cook the batteries? I would think that a charger that monitors the charge level automatically would be better for the batteries in the long run.
You are correct but it will drop out of boost mode by itself down to 13.6 then if you want you can put it back into it, but it will drop down by itself when it reads the voltage.
As far as the person who asked about getting the pendant, if you get the WFCO 8955 / replacement the new board has a button that you push and you do not need to buy a pendant. Progressive makes a 55 amp direct replacement.
To the OP Your best bet would be just buy turbs, It is a very good power center also, and is also a direct replacement...
Coachmen M/H
Concord
2018 / 300 DSC
Old 01-29-2016, 06:18 AM   #20
TURBS's Avatar
I bought it to to put in my unit that was supposed to have a Wfco "junk" as it turned out it was a progressive dynamics.
2015 Columbus 320RS
2008 2500HD Duramax
converter
