Old 01-30-2016, 09:39 PM   #31
Garrette's Avatar
No pitfalls. Unpaid Rv from 110v power and use the battery disconnect in the step well.
I removed everything from the wet bay including the divider and the black flex cover over the WIFCO.
Inside, I stood the mattress up at the end of bed after putting the slide out. Than removed the storage door and wood cover. This is where I used the vacuum to get all of the construction debris. Well, all I could reach.
Find the 110v receptacle and unplug the converter. Start removing the black foam until the wire is free and the hole to the wet bay is clear.
Feed the wire thru Into the wet bay, disconnect the red, white and ground wires from the WIFCO. Remove WIFCO.
Install the progressive using the same screws, attach wires, feed 110v line to the receptacle.
On the inside. If you want the wizard in the bedroom, feed it thru the same hole and mount in a convenient location.
When I plugged in the 110v line, I used a couple of ties to secure the plug.
Double check your work, turn the battery disconnect on and plug in the 110v or run the genny. Check the wizard lights.
After you are satisfied, get your can of expanding foam, red can with yellow top, great stuff and fill everything. Be generous.
Reassemble the wet bay and the bed. Approx total time for me, 3 hours.
Good time to take reference photos.
I may have forgotten something, so be careful. Hope this helps. Sorry about being wordey.
Garrette is offline   Reply With Quote
Old 01-31-2016, 10:33 AM   #32
geezer with gadgets
757Dave's Avatar
Garrette,
Thanks for the response. This helps clear up some confusion I was having. Your wordey response is greatly appreciated!
PM sent
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 48
757Dave is offline   Reply With Quote
Old 01-31-2016, 02:16 PM   #33
Garrette's Avatar
You are welcome. I purchased
Name:	ImageUploadedByForest River Forums1454271239.378593.jpg
From Amazon. It came with the wizard. Have fun.
Old 01-31-2016, 02:38 PM   #34
TURBS's Avatar
Best converter is $20.00 cheaper
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 01-31-2016, 02:44 PM   #35
geezer with gadgets
757Dave's Avatar
Attachment 98695
Thanks for all the info!
Old 01-31-2016, 02:47 PM   #36
Cool...did it come with the pendant as well? There seems to be some disagreement about whether it comes with the pendant at retail or at wholesale. Pendant is about $12.00 if you need to add it in. It has the Wizard built in but the pendant is an add on.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 01-31-2016, 03:10 PM   #37
TURBS's Avatar
Remote pendant comes with it.
http://www.bestconverter.com/9200-Se...ount_c_84.html
2015 Columbus 320RS
2008 2500HD Duramax
Old 01-31-2016, 08:56 PM   #38
Garrette's Avatar
The unit I purchased, with that part number came with a pendent. I think the units are offered with and with, depending on part number.
converter
