Old 01-28-2016, 11:00 AM   #1
geezer with gadgets
757Dave's Avatar
Converter has died
My converter has died. Had the elecrician came and checked and he confirmed the death.
I'm looking at the progressive dynamics converter with the charge wizard for replacement. The old WFCO unit is 55 amp (MH is 30 amp). Do I need to match the amps to the old unit? I can find 45 amp, 60 amp, etc., but not 55 amp.
Thanks in advance for your help.
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 57 2019: 5
757Dave is offline   Reply With Quote
Old 01-28-2016, 11:33 AM   #2
Kenny kustom's Avatar
You can go up to the 60. No problem.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 01-28-2016, 11:34 AM   #3
Stank Bait's Avatar
Think this may be what you are looking to find.
55 Amp (PD4655V)
Inteli-Power 55 Amp Converter/Charger
Model #PD4655V replaces these converter sections: Parallax/Magnatek #6355, Parallax #7355, Parallax #7155,
Parallax #8355, WFCO™ #8955
2013 Flagstaff 831FKBSS
Stank Bait is offline   Reply With Quote
Old 01-28-2016, 11:44 AM   #4
TURBS's Avatar
Converter has died
I have one for sale.
Drop in replacement.
New in the box never opened.
http://www.bestconverter.com/8955MBA...l#.VqpFLkVOLCQ
Randy at best converter recommend this over a progressive dynamics.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 01-28-2016, 11:49 AM   #5
TURBS's Avatar
Can ship today!
2015 Columbus 320RS
2008 2500HD Duramax
Old 01-28-2016, 11:52 AM   #6
2015 Columbus 320RS
2008 2500HD Duramax
Best bet right here!!
2016 Sabre 36QBOK
Old 01-28-2016, 01:31 PM   #7
One advantage of the Progressive Dynamics line is that you can connect a pendant and FORCE the converter to go into boost mode. This means that if you boondocking and using a generator, you can maximize the few hours of run time to get as much battery charge as possible. The PowerMax does not appear to offer any manual control of charge level. If you aren't boondocking it really doesn't matter.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 01-28-2016, 01:52 PM   #8
TURBS's Avatar
Boondocker also has a a boost mode 14.6v
KEY FEATURES:
14.6 Boost Mode Output
13.6 Normal Mode Output
13.2 Float (trickle) Mode Output
Built-in desulfation cycle
Over-temp, Over-current Protection
Temperature tested to 160 F
105-130 VAC Input Operation
Reversed Polarity Voltage Protection
>85% Efficiency
Safe, Cool, Quiet & Reliable Operation
<1% Load Regulation
Constant Current Charging Technology
Filtered DC Output (Works with or without a battery)
Thermostatically Controlled, Variable Speed Quiet Cooling Fan
3 Year Hassle Free Limited Warranty
2015 Columbus 320RS
2008 2500HD Duramax
Old 01-28-2016, 05:09 PM   #9
For sure it does, no converter could work without one. However, you can't force it to go into Boost mode, it makes its own decision and when it drops out you get a very low charge rate. If you are persistently plugged in, that is no problem. However, if you are cranking a generator while boondocking, as soon as it drops out of boost, you get what you get.
2015 335DS
Old 01-28-2016, 05:26 PM   #10
AquaMan's Avatar
What happens if you forget the boost mode is on, since it is manual, and you run a long charge? Will it cook the batteries? I would think that a charger that monitors the charge level automatically would be better for the batteries in the long run.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
converter
