Old 11-28-2015, 05:24 PM   #1
17Racer's Avatar
Convex Mirror Options for 2014 Chevy 4500 MH
Have need for a larger add on convex mirror for a 2014 Chevy Express chassis motorhome. Does anybody have experience in selecting a good set and what was used? Were there any problems mounting them? Thanks.
17Racer is offline   Reply With Quote
Old 11-30-2015, 05:47 PM   #2
Total Loss's Avatar
I am interested also.
Looking for something I can attach to the lower portion of the mirror housing.
Typical auto parts stores don't seem to have anything.
Total Loss is offline   Reply With Quote
Old 11-30-2015, 07:38 PM   #3
17Racer's Avatar
Thanks for your reply. Guess most are happy with the stock offering on mirrors.
I am a retired toolmaker so the need to put my skills to work again is most likely needed. Thinking the same place as you mentioned. The housing seems to be some sort of plastic.
Will be making plans for most likely a 6 inch round convex mirror. Will need to make an aluminum bracket to hold the new mirror and attach bracket with 2 threaded bushings and screws for proper strength. Will keep you up to date on progress and plans. First thing to check will be if the electric main mirror will tilt far enough up to expose the bottom area better.
Old 12-01-2015, 12:18 AM   #4
The mirror on the far right on the Bus/Transit page would have been my preference:
Bus / Transit | Velvac
Even on our new 2016, we still have the same Velvac mirrors as those that were on our 2000 Four Winds. If anything, I can replace the heads with this new style, but I'm not ready to toss the money at them just yet...
Ryder Fleet Products carries Velvac mirrors - here's a link to their page:
Velvac Mirrors, Convex Mirrors Rear & Side View Truck Mirrors
The one on the right is only $87, each.
2016 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
brucemc is offline   Reply With Quote
Old 12-01-2015, 11:34 AM   #5
Total Loss's Avatar
Good idea.
I have some alum laying around also.
I also have some textured black plastic sheet to make it blend in.
May do the same if I cannot find anything.
Right now- I have a big fab project to start- 2 additional receivers for the rear frame/bumper for a motorcycle rack. Cut/hack/weld in my future.
Old 12-03-2015, 05:32 PM   #6
Hoglou's Avatar
Total Loss -
So you will have three? Interesting. If the outer two were above the bumper I could still blue ox the toad and my DW can continue planning hub and spoke excursions .. (wow, we have our own language!)
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 12-03-2015, 06:38 PM   #7
Total Loss's Avatar
Originally Posted by Hoglou View Post
Total Loss -
Thats the plan.
I decided to weld them to the underside of the square bumper and bolt them to the frame using the existing bumper bolts and one other lower frame bolt tab. 3/16 plate should do the trick and grade 8 bolts.
The M/C rack will still be above the stock hitch height enough to use the towbar beneath the rack for towing the toad.
And then the bumper will unbolt with the 2 outer receivers if need be.
If I don't take a toad along, I can still use the center receiver for a bicycle rack. 1 motorcycle and 2 bicycles with about 525 lbs on the rear frame.
The 4500 springs should be able to handle that. If not- some air bags next.
I have built these before and they work great.
You can even set the rack up to allow the bike to "float" on the rack where the suspension still works.
I used to have a setup on a prerunner truck I had where I could jump the truck with the dirt bike on the back rack.
May post up when done.
Old 12-07-2015, 11:49 PM   #8
17Racer's Avatar
Well my mirror project is done. If you care to see the results check the pdf file.
http://users.snip.net/~mogul/MH/Mirror.pdf
Old 12-08-2015, 12:24 AM   #9
That's pretty cool! I was thinking of something similar to give the passenger a decent mirror as the main passenger mirror is adjusted for me (the driver). All the passenger can see is the side/front corner of the coach.
2016 2250LE/Chevy
Old 12-08-2015, 11:18 AM   #10
Total Loss's Avatar
Great job...and great write-up.
I may copy you.
It looks as if you removed the spot mirror attached to the factory mirror.
Seems that will give you a lot more visibility down the side of the box.
Looks like my next project when I am done with the motorcycle rack.
Thanks a bunch.
"If you are going through hell..keep going"
W. Churchill
