Old 07-16-2018, 08:14 PM   #1
Crack in Shower Stall
Hi everyone!
I have a crack that started right at the connection that holds the shower head on in the plastic. We covered it with packing tape and its been that way for a while with no problems and it has not propagated.
Does anyone know what type of plastic we have on the side walls of the shower?
Any suggestions on how to repair this crack?
Also my plastic seal on the bottom of the door has torn. Any suggestions on what to replace it with?
Thanks!
Mike
MikeRP is offline   Reply With Quote
Old 07-16-2018, 08:17 PM   #2
asquared's Avatar
On my Sabre the shower is fiberglass. When ours cracked, it was under warranty and they had a fiberglass specialist repair it. I would be leary of the packing tape as it is not likely preventing any water damage from occuring.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 07-17-2018, 08:47 AM   #3
I also have a crack and will attempt a fix soon.
I plan to try Bondic and see if this plastic weld kit will work. I will post results later...
A short term fix might be the clear Gorilla tape.
sask is offline   Reply With Quote
Old 07-17-2018, 02:24 PM   #4
So here is my attempt with Bondic . I actually had 2 cracks originating from same point at the edge. I cleaned the area with alcohol and pushed the crack in and out to get the adhesive onto the edge of the plastic. I used the UV light and cured it. I then applied a couple of more layers on top of the crack. It hardens with a bit of an off white colour which is noticeable. I will leave it and see if the adhesive weld holds. If yes then maybe some touch up paint to hide the weld.
Old 07-17-2018, 03:53 PM   #5
That looks almost exactly like mine but in a different location thanks!
Old 07-18-2018, 01:09 PM   #6
Attachment 180040
Attachment 180041
Attachment 180042
Drilling the holes to stop the crack run is a good idea. I would have probably used some kitchin/ bath caulk in white. My thought us the color would blend better and the caulk is somewhat flexible. Good luck.
Luke Moseley is offline   Reply With Quote
Old 07-18-2018, 01:27 PM   #7
amblt's Avatar
I've had good luck with clear silicone aquarium sealant. It seems to adhere well to most surfaces, and is not as visible as you may think. (it is very shiny, however).
It's held a few badges to a pewter mug for nearly 40 years.
Cheers
amblt is offline   Reply With Quote
Old 07-18-2018, 01:29 PM   #8
Prime Member
How about Eternabond tape?
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 07-18-2018, 03:52 PM   #9
Hoglou's Avatar
Sask.. looks good thus far. Is the repair material soft or rock hard? Given the viscosity I would razor cut or dremel to match the surface and paint with acrylic (like from hobby lobby). I bet 30 minutes would make blend pretty nice.
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 07-18-2018, 03:55 PM   #10
Duckogram's Avatar
I don’t think bondic will hold up on pvc but worth a try
ILB ( | )
crack, show, shower
