Old 08-07-2015, 08:32 AM   #11
Class C Representative
Joshua Cavitt's Avatar
Just to clarify this is the fiberglass on the bottom of the coach not a sidewall. We use the fiberglass in place of Darko for extra reinforcement. Having it epoxied should not be an issue.
Joshua Cavitt is offline   Reply With Quote
Old 08-07-2015, 09:28 AM   #12
Boso's Avatar
Joshua you are saying that the crack is underneath the rv not on the sidewall and will it be visible when finished I thought it was running down the sides
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 08-07-2015, 10:52 AM   #13
It is underneath the coach. You can see the rear axle in the back of the picture. The crack is cosmetic but it depends on how extensive Brandit and the dealer want to go with the repair.
Old 08-07-2015, 11:35 AM   #14
Tinkerer and Putterer
Heck reseal it and then rhino line the undercarriage. You'll never see it again and you'll be impervious to rust on the rest of the frame. You're walking around on wood and not fiberglass so I wouldn't be too worried about that crack as long as it gets sealed to prevent water penetration.
HappyGuy is offline   Reply With Quote
Old 08-07-2015, 04:33 PM   #15
toslow's Avatar
so did the customer pay extra for the crack?
haven a blast
toslow is offline   Reply With Quote
Old 08-07-2015, 05:43 PM   #16
From the sounds of it service is working with Brandit and giving some direction of what steps to take.
PLEASE do not send questions via Profile comments or Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Old 08-07-2015, 10:48 PM   #17
To say this is cosmetic is misleading at best...I have a very similar one towards the front of my Forester (2013 3171 DS) that I only discovered because the floor was soft! The crack in mine goes all the way to the floor covering. I added a brace between chassis floor supports to fix it. Will also under coat when I'm satisfied with it. I'll m super careful with the levelers, but not sure how else something like this could happen.
EXTremist is offline   Reply With Quote
Old 08-08-2015, 03:48 PM   #18
Boso's Avatar
Wondering if FR is paying for this job I certainly hope so even if out of warranty
