Old 06-03-2016, 10:40 PM   #1
Chief tinkerer
Gidyupgo's Avatar
Dangerous Blind Spot on Side Camera 2017 3010DS
I contacted my dealer, described the condition where the new location of the passenger side, side camera's field of vision is obstructed by the coach door hinge. This prevents you from seeing a vehicle overtaking you on the right side and gives you a false sense that it is clear to change lanes. The camera simply needs either spaced out further or a taller camera installed so it protrudes past the coach door hinge.
The reply from my dealer's warranty department was that his contact at Sunseeker said that they do not have a repair for this problem. Beware of this hazard and lack of interest and urgency in correcting it by Sunseeker.
Gary
2017 SunSeeker 3010DS
Gidyupgo is online now   Reply With Quote
Old 06-04-2016, 10:44 AM   #2
Chief tinkerer
Gidyupgo's Avatar
Just dropped it off at Three Way Campers in Marietta for them to see what they can do.
ID:	110115   Click image for larger version
Gary
Old 06-05-2016, 01:41 AM   #3
benagi's Avatar
Did they move the camera from the mirror? My 2016 3171 has the side cameras mounted in the side mirrors . No problem with side view.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 06-05-2016, 05:49 AM   #4
Difficult problem and there doesn't seem to be much room there. They could just put a small spacer under the camera to move the lens out so that it can see beyond the hinge. relatively simple fix but hopefully it is forward enough that the door doesn't contact it when opens beyond 90 degrees. Won't take much, maybe 1/2 if an inch. A white nylon plate under the camera should do it and even allow them to nudge the camera forward to clear the door.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 06-05-2016, 05:51 AM   #5
Is it possible for you to make a spacer to get it out past the hinge and use longer screws? Just make sure you caulk behind the spacer and the screws.
Another possible solution is move the camera to another location and add a cover to the old position.
Old 06-05-2016, 06:14 AM   #6
bubbles's Avatar
Here's a thought. Why not just use your mirrors, like in the old days.
Old 06-05-2016, 06:31 AM   #7
DaGrinch's Avatar
I have the same unit and the door does not contact the camera. Camera is far enough ahead of the door and door is restricted by the gas strut.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 06-05-2016, 06:37 AM   #8
Great. Then it is easy. small chunk of 1/2" nylon or other white plastic, some sealant and the camera will won't be blocked by the hinge.
2015 335DS
Old 06-05-2016, 07:09 AM   #9
B and B's Avatar
Red Souvine would use his mirrors but this is 2016. The spacer mentioned looks like the best option.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 06-05-2016, 12:30 PM   #10
grumpy0374's Avatar
Wow!!! What a great idea!!! Never realized you could use em for that.
Seriously, my mirrors have both the regular and convex lenses, and I have no problem with seeing all I need to on both sides of our Lexi.
The side view camera's may be a convience, but think about what you used in the olden days...a mirror.
Next everyone will be thinking of a way to check the airpressure in the tires without using a tire pressure guage!!!
What will they think of next?
Grumpy
Steve & Cheryl + Charlie, Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
