Old 04-30-2013, 06:22 AM   #1
Decal Replacement
Need to replace decals on 2006 3100SS. Has anyone done this and approximate cost. Also where to order decals
dojo is offline   Reply With Quote
Old 04-30-2013, 07:45 AM   #2
MotocrossCamper's Avatar
I have considered it on ours. You can spend as little or as much as you want depending on what you want to do. If you have a shop near by that does vehicle wraps, they are one of the better places to look into. Their stuff will hold up a lot longer then the original decal material. They can do anything you want, if you want to keep it original they can do that. Or if you see a design on another RV you like they can do that to. I did a race trailer that was way more work then redoing a motorhome and it cost $800.
MotocrossCamper is offline   Reply With Quote
Old 04-30-2013, 08:46 AM   #3
GM
bclemens's Avatar
You can order a brand new 2013 set from the dealer...or the set for your model year. or as Motocross said, a custom set. Costs I don't know.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
