Old 10-16-2013, 04:49 PM   #1
Chrisbrock's Avatar
Send a message via Skype™ to Chrisbrock
Dehumidifying
So I run a decent size dehumidifier in the evenings and turn it off in the morning when I get up. Is there such a thing as TO much dehumidifying?
Every morning when I get up and turn it off I empty the bucket and pour out about a 1/2 gallon of water
Here is a photo of the unit below
Christopher Brock
2014 Sunseeker 3170ds
2012 Honda Odyssey
2003 Hummer H2
2003 IS300
Chrisbrock is offline   Reply With Quote
Old 10-16-2013, 04:51 PM   #2
Chrisbrock's Avatar
Christopher Brock
2012 Honda Odyssey
2003 Hummer H2
2003 IS300
Old 10-20-2013, 10:31 AM   #3
Love My Sunseeker
DXSMac's Avatar
I don't think so. I'm running a 3 amp EVA-DRY dehumidifier (LOVE IT!) and I also have Damp-Rid's hanging in the driving cockpit and in all my closets, and I have a DRI-Z-AIR in the bathroon. Now is THAT too much dehumidifying?
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
Old 10-20-2013, 10:34 AM   #4
Ford Idaho's Avatar
I looked at the ones you can hang up, how often do you replace them?
Old 10-20-2013, 10:56 AM   #5
acadianbob's Avatar
I think it depends on the time of year and where you live. Atlanta? Leave it on. 1/2 gal a day indicates a lot of humidity. Do you have a humidistat on the unit? Just set it at a reasonable humidity level.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 10-20-2013, 09:10 PM   #6
Chrisbrock's Avatar
I have a digital read out that says for the most part I am at 40-50% humidity
Christopher Brock
2012 Honda Odyssey
2003 Hummer H2
2003 IS300
Old 10-20-2013, 09:57 PM   #7
In a short answer - yes you can do too much dehumidifying - when occupied. Too dry will dry YOU out.
Unoccupied, it is not necessary to dehumidify a camper.
If you are wondering where all the moisture is coming from when unoccupied, it is likely from the surroundings. Like your air conditioner, even if you don't open any doors the unit has to cycle on to remove the heat through absorption. Campers, like homes aren't drum tight. Moisture is migrating from outside.
After a trip in the coach it would be ok to run the humidifier for a couple days to dry it from the occupants but you will not likely ever to see a day of never emptying the bucket until the outdoor average daily humidity levels are around 35% or lower.
Bobby
bgilly is offline   Reply With Quote
Old 10-20-2013, 10:41 PM   #8
Retired on the weekends
The RB's Avatar
In Washington State, in fall we run our dehumidifier while we're camping. I turn it off and on throughout the day, but let it run on low during the night. It keeps the windows clear and the temperature more comfortable. I have one like the picture above. Dining the winter, we semi-winterize, because we like to get out and about after a long week at work. I let it run down to about 40% humidity.
The RB is offline   Reply With Quote
Old 10-20-2013, 11:15 PM   #9
Denver, CO
garbonz's Avatar
If you can keep the humidity below about 45% or so, it will impend the growth of mold... That is probably a worthwhile endevour. Out here in Denver, we don't see it that high very often, more like 15% most times except when early in the morning during the winter or when it's raining.
Of course we did have a little stint here a month or so ago that was not much fun, but hopefully not again for 500 years or so.
2017 Fuse 23T
Old 10-21-2013, 04:15 AM   #10
Witch Doctor's Avatar
To answer your question yes you can. You can dry out your cabinets and furniture. Your relative humidity should run around 45 to 50%. On the other hand it depends on the time of year. During the summer your A/C is really just dehumidifier. During the winter if you run your propane furnace you add to the humidity in the trailer. If you allow humidity to build in the winter by keeping the unit closed up you stand to grow mold and mildew, the same as the hot summer months. It is safer to leave some roof vents open so you can exchange the air. Propane is not a dry heat like a firer place. I would use one during the winter in storage, but that would be about it. When I was in the HVAC business we use to add humidifiers to people systems for use in the winter only so the heat would not dry things out.(natural gas) During the summer months the A/C took care of dropping the humidity on it's own.( condensation) But there is a moisture content with propane and with the btu's each person puts out on their own. When we calculate the size of A/C's you add that in as a factor. Plus fresh air intake.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
