Old 12-27-2014, 10:28 AM   #1
Dewinterize question
So my wife and I will be taking our first long trip over the new year. I want to dewinterize it here in PA so once I'm on the road going south, I only focus on the vacation at hand. My question is this... if I dewinterize the day before and run heat into th e camper the night before, do I have anything to worry about freezing (if I'm not running water into the camper)? Are there risks of any external water lines freezing, or maybe my question really is... are there external water lines or will simply heating the interior be enough?
jjlavin is offline   Reply With Quote
Old 12-27-2014, 10:49 AM   #2
davel1971's Avatar
how are you dewinterizing without using water?
David & Lynn
Old 12-27-2014, 10:54 AM   #3
I will use water to flush the antifreeze out of the lines, but if the interior is completely heated, will I still have a potential freezing problem?
Old 12-27-2014, 10:55 AM   #4
davel1971's Avatar
do you have a trailer, class c or class a? Anything on the exterior is in danger of freezing
David & Lynn
Old 12-27-2014, 11:02 AM   #5
Class c
Old 12-27-2014, 11:05 AM   #6
itch'n to road trip
campnqueen's Avatar
Send a message via AIM to campnqueen Send a message via MSN to campnqueen Send a message via Yahoo to campnqueen
Blow out your lines and leave your faucets open.
2012 Ford F-250 King Ranch Super Crew Cab 4x4 "Mae West"
2014 Work & Play 25ULA "Ula"
Paula Drake, Ken Cooksey, Sunny Delight, Valor & Scarlet Begonia
Jasper Ga.
campnqueen is offline   Reply With Quote
Old 12-27-2014, 11:17 AM   #7
davel1971's Avatar
you will also need to winterize before coming home if coming back to freezing temps
David & Lynn
Old 12-27-2014, 11:54 AM   #8
WFD
You will absolutely have water in the lines or low spots after dewinterizing. There is no mystery in dewinterizing, just flush copious amounts of water through the system. Personally I would not dewinterize till you are in warmer weather. If you dewinterize before leaving, you will have to partially winterize before leaving anyhow, even if if just blowing out the lines, so why bother? Just wait till you are in warmer weather, hook up to city water connection at your first campsite and flush away. If you are winterized right now, why would you take the risk by dewinterizing and suddenly a hard freeze comes one night, and you expose yourself to possible problems.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 12-27-2014, 12:44 PM   #9
Unruly's Avatar
We left PA the beginning of November with a winterized trailer and de-winterized once we were in warmer weather just to be safe. If you are still in PA I would not de-winterize until you get south. It only takes about five minutes to flush it out and possibly save you a lot of money if you freeze lines or a tank.....
Bill and Sarah
Edinboro Pa
2008 F350 Lariat Crew Cab Diesel DRW 4X4
2012 Sabre 34REQS
Unruly is offline   Reply With Quote
Old 12-27-2014, 01:41 PM   #10
Ok. All great advice. Will definitely do that. 1st stop in warmer weather... dewinterize! Thanks all
winter, winterize
