Old 10-07-2014, 08:32 PM   #11
rbetzwieser's Avatar
Originally Posted by Ramblin Recks View Post
I installed the new bi-directional Winegard Rayzar Air antenna. Installed in minutes and went from 10 channels to 16 channels where we were camping at the time, including low band vhf, which is supposed to be questionable with this antenna. HD quality, and looks as good as the Batwing. (Kept the batwing just in case !)
Do you have a part number for this antenna?
rbetzwieser is offline   Reply With Quote
Old 10-07-2014, 08:43 PM   #12
CCRVOC
Ramblin Recks's Avatar
Winegard Rayzar Air Amplified TV Antenna
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB, 4x4, 3:73, Retrax Pro, Q20, TST507, Garmin RV760, Sleek 4g
2014 Cedar Creek, 36CKTS, 640w Solar, TriStar MPPT 60, Magnum 2000w, PI EMS, WiFi Ranger Elite, Sleek 4g, Wingard DTV Traveler
Retired Army in 1995, and now retired in 2016
Ramblin Recks is offline   Reply With Quote
Old 10-07-2014, 08:45 PM   #13
Ret E-9 Anchor-clanker
donanddona's Avatar
If were talking about this one,
It can be seen at:
Jack Aerial Mount HDTV Antenna ó 12 1/2in.L x 16in.W x 12 1/4in.H, Model# OA8200 | TV DVD| Northern Tool + Equipment Goods + Toys-_-Electronics-_-27672
Two cousins have had them installed (04 Sunrise coach and a 04 coachman coach) with a slight increase in reception. But have good sleep not worrying about raising or lowering it. A series of lights inside the coach tell the strongest signal. Fits right where the standard crank goes. Just have to drill an slightly larger hole. Now hears the rub. The third cousin had a metal roof (Travel Trailer) and after three days of installing not one, not two, yes three of them it was determined the metal roof causes a ground. Who would of thought.
donanddona is offline   Reply With Quote
Old 10-08-2014, 09:54 PM   #14
Yes, It bolts right on to the existing batwing mast. Remove the existing antenna from the mast, and bolt the razor onto the same mast. Took about 10 minutes. No need to touch the roof mount.
Perfect! Thanks. That's going to be my next mod. I've been having troubles picking up some stations. They'll work for a while but the signal is weak and they cut in and out.
jst3 is offline   Reply With Quote
Old 10-13-2014, 04:25 PM   #15
Garrette's Avatar
There is an app called TV Towers that helps me to turn my antenna, at least in the general direction, of the strongest stations. It works on my iPhone.
Garrette is offline   Reply With Quote
Old 10-14-2014, 09:19 PM   #16
Originally Posted by bclemens View Post
We're running Jack Digital Antennas as our standard antenna now.
Fixed mast, no crank up...but it does swivel to maximize the signal. Built in meter tells you the signal strength before you ever scan for channels. Seems to work as well if not better then the Wineguard (at least our testing, mileage may vary) without the hassles.
Thanks for the info. I am thinking of installing a jack digital antenna on my sunseeker 3170ds I believe it is a fiberglass roof. It sounds like I will have to make the original hole larger. What will be the best method to enlarge the hole. Thanks for all your great information you provide to the site.
scoto is offline   Reply With Quote
Old 11-27-2014, 06:44 AM   #17
amishgirl's Avatar
When you say batwing, which antenna system are you talking about. The old Wineguard Sensor IV or the King Digital?
amishgirl is offline   Reply With Quote
Old 11-27-2014, 09:51 AM   #18
GM
bclemens's Avatar
Just to remind everyone...instead of going through all the trouble installing a new antenna...All new Sunseekers come with the Jack Digital Antenna - Standard.
No work...just more paperwork to sign
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 11-27-2014, 09:54 AM   #19
Sure now you tell me. Mine was just in your shop. Could of had them install it.
Old 11-27-2014, 06:09 PM   #20
digital
I just bought the 337 BAR and am having problems getting channels thru the fixed antenna. Not a fan of the new antenna. Does anyone have ideas of troubleshooting to get more channels? I am picking up more digital channels on the bedroom tv, but when I run channel search on living room tv, very little digital and/or analog channels. The cable feeds appear not bad in quality also.
hateuserenames is offline   Reply With Quote
antenna
