Old 10-06-2014, 07:21 PM   #1
rbetzwieser's Avatar
Digital TV Antenna
Does anyone know how much better, if at all, the new fixed mast digital antennas are as compared to the "old" winegard crank up one's. Has anyone switched over? Easy to retrofit?
rbetzwieser is offline   Reply With Quote
Old 10-06-2014, 07:33 PM   #2
CCRVOC
Ramblin Recks's Avatar
I installed the new bi-directional Winegard Rayzar Air antenna. Installed in minutes and went from 10 channels to 16 channels where we were camping at the time, including low band vhf, which is supposed to be questionable with this antenna. HD quality, and looks as good as the Batwing. (Kept the batwing just in case !)
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB, 4x4, 3:73, Retrax Pro, Q20, TST507, Garmin RV760, Sleek 4g
2014 Cedar Creek, 36CKTS, 640w Solar, TriStar MPPT 60, Magnum 2000w, PI EMS, WiFi Ranger Elite, Sleek 4g, Wingard DTV Traveler
Retired Army in 1995, and now retired in 2016
Ramblin Recks is offline   Reply With Quote
Old 10-06-2014, 07:54 PM   #3
Did not even know this existed. Might have to get one of these! Thanks.
Old 10-07-2014, 10:14 AM   #4
GM
bclemens's Avatar
We're running Jack Digital Antennas as our standard antenna now.
Fixed mast, no crank up...but it does swivel to maximize the signal. Built in meter tells you the signal strength before you ever scan for channels. Seems to work as well if not better then the Wineguard (at least our testing, mileage may vary) without the hassles.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 10-07-2014, 10:34 AM   #5
Fellow camper where we have a seasonal site has one on his new camper. Works great!!
Old 10-07-2014, 10:45 AM   #6
Witch Doctor's Avatar
I'm glad that FR seen the light, a year ago I was told that FR was debating and testing the Jack antenna. Why don't you guys check tires? I will be glad to drive the test unit around for you to see how they wear...
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-07-2014, 02:56 PM   #7
Will the jack antenna retrofit easily where my winegard is now?
Old 10-07-2014, 08:04 PM   #8
Does this bolt on to the existing base? So I can retrofit without removing screws in the roof and having to seal a new base to the roof of the MH?
jst3 is offline   Reply With Quote
Old 10-07-2014, 08:19 PM   #9
I put a Jack antenna on the Winegard mast. Works great and pulls in many more channels--- some of which I don't get with FIOS at the S&B. It is direction sensitive.
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 13 days
mogman is offline   Reply With Quote
Old 10-07-2014, 08:20 PM   #10
CCRVOC
Yes, It bolts right on to the existing batwing mast. Remove the existing antenna from the mast, and bolt the razor onto the same mast. Took about 10 minutes. No need to touch the roof mount.
antenna
