Old 06-30-2014, 09:03 AM   #11
GM
bclemens's Avatar
Jumper Diagram
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 07-03-2014, 05:00 AM   #12
Contacted dealer he was clueless. Any way u could send some pics
cvf1969@yahoo.com
Thank you
chucknviv is offline   Reply With Quote
Old 07-03-2014, 10:26 AM   #13
over door cabinet
Do you have a part number for the over the door cabinet for the 2015 3010DS?? Thanks, Kevin
Kevin & Judy is offline   Reply With Quote
Old 07-03-2014, 10:53 AM   #14
Just spoke to the my service/parts guy. He said there isn't a part number for that type of wood product. I trust his answer because its in and ready to be installed.
mve6464 is offline   Reply With Quote
Old 07-03-2014, 11:02 AM   #15
over door cabinet
Ok, So how can i order one? They had to have some type of number to order it?/
Kevin
Old 07-03-2014, 11:32 AM   #16
I'll call him back and let you know.
Old 07-06-2014, 08:13 PM   #17
I would like to order a shelf that fits under the TV to put my satillite box. I see it in the Sunseeker brouchere but do not know how to order. I spoke with my parts dept and they had no idea.
Old 08-25-2014, 10:03 AM   #18
Originally Posted by bclemens View Post
Jumper Diagram
i Have the same issue. i am not good at diagrams. In my 2015 Sunseeker 3010 dsf i have a dish tv box installed above the door. In the cabinet underneath the box I see a plate with two connections joined by a short jumper cable. This is on the top of the cabinet. On the left wall there is a 12 volt/ cable plate. The tv is converted to run off 12 volt power and is plugged in there and a cable is in the cable port. I activated my dish and I only get dish on the living room tv. Can you walk me through what i need to do for the outside and bedroom to show dish as well. I was told by the dealer it should work that way...any help would be appreciated.
glfairjr is offline   Reply With Quote
Old 08-25-2014, 11:01 AM   #19
GM
bclemens's Avatar
Pretty simply, the top connection goes to the antenna booster then then out to all TV's. So from your Satellite, you need to connect the coax output into that coax connection (remove the jumper). This will not be in HD, and you need to make sure the antenna booster is off.
I'm guessing right now, you recover feeds the TV directly (so red/white/yellow or HDMI) which is the best connection.
Old 08-26-2014, 04:50 AM   #20
ok i went in my coach and removed the jumper cable. Nothing happened I still have dish tv on my living room tv but the bedroom and outside still have nothing. did i miss a step?
